I've noticed they have 85% Bio here in town that is much cheaper. Can this be ran in a stock PSD?
Can it be ran straight or would I need to mix it with #2?
Just run it straight in your truck, it isn't going to hurt it.
yea put it in the truck and run it. with summer coming up you will be fine. You may want to be slightly worried come winter time but when that time comes just set a sample outside and when it starts to get hazy put some more #2 in the truck
i'm sure you already have 2nd fuel filter on your truck. that would be my only other suggestion
Higgins
2000 F350 SRW Extended cab, AIS, Muffler Delete,BTS VB,DP Tunner tuning, Isspro Guages,255/85/16's
Running B100:Man these injectors love this stuff
Were running 100% in the 97 PSD. Last night down in low 40's, started and ran fine this morning.
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
Has anyone tried mixing/blending B85 with WVO? This maybe a No-No, But it crossed my mind and I thought I would ask. I am going ot receive a few drums of B85 and thought I could get it to last a little longer by mixing some WVO with it.
2004 Ford F350 crew cab dually w/ 6.0 automatic.
It's a no-no. Mixing WVO and diesel is generally a bad idea in an unheated system.
If this is your first time running B85, or any blend of biodiesel, carry an extra fuel filter or two. Bio acts like a detergent, and will flush out all the crud that has accumulated in your system over time. The first couple tanks will clean the system out, and you won't have to worry about it after that.
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'96 International/Bluebird school bus, DT466, homemade WVO system, www.thebiggreenbus.org
'04 Jetta TDI, Greasecar WVO conversion (chases the bus around the country)
'89 MCI 102A3, Detroit 8V92TA, Frybrid/Rover Hybrids custom system
