I'm sure this issue has been addressed before, but I'm leery of using the search utility on this forum
I'm going to buy a 55 gallon drum of methanol and then divide it up into 5 gallon carboys for later use.
What I need to know is, what is a good pump that is cheap and easily obtainable but isn't going to crap out over time due to the corrosive nature of methanol?
Thoughts and experiences please.
I use one of those barrel siphon pumps (Mechanical). For same purpose, to divide a 55 gallon drum into 5 gallon scribner jugs. The wife is terrified of storing a 55 gallon drum... Go figure. Takes about 25 to 30 minutes to empty the barrel.
I was going to use a Harbor Freight pump just like the one that I have been using for transfering WVO, but I read that it wont take corrisive fluids for very long before it takes a dive.
Do you have anymore information about that barrel siphon pump and where I can get one?
I use air pressure.
Made a pickup to thread down the 3/4 bung hole with a 90 and a valve on it.
In the 2" bong hole, I put a bung off of a plastic barrel with a tire valve installed in it. I use a tire inflator to pressurize the drum.
It does not take much pressure to get it going on 3-4 psi.
The pick up I made using a length of 1/2 sch 40 steel pipe, on the bottom end I put a notch in it so it would not plug up sitting on the bottom of the barrel. I then took a 3/4" schd 40 steel nipple about 3 or 4" long. I stuck the 1/2 up through the center of the 3/4" (had to make it fit) then brazed the end of the 1/2" just below the threads on the 3/4", that way I did not mess up the threads. When installed in the barrel you have a 3/4" pipe thread male sticking up, add a 90 on that another nipple to a valve then an adapter to reinforced 3/4" plastic hose and wha la!
No effort what so ever!
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
A pressurized drum of methanol?! Sorry but no thanks.
I said 3-4 psi, you do not think that temp fluctuations get the pressure up that much or MORE? I'd be willing to bet more than that, ever hear it hiss when you remove the bung?
Rick H...
HIS
HERS
I lived in South O and Bellevue for about 8 total years as a child, Dad was in the Air Force.
Still visit at least annually. Still love Fontenelle Forest!!!
We are in old towne, 2 minutes from offits front gate.
East end of the forest, dang deere eat everything!
And leaves up the yng yang!
Look me up if you come to town.
Rick H...
HIS
HERS
Still you have a pressurized vessel with an explosive fuel. No thanks, ever hear of the Apollo 1 fire?
What ever, all I am is saying while it is sitting there is storage it has more pressure on it than when I use my method of fluid transfer.
Rick H...
HIS
HERS
Yeah Apollo one was pressurized with PURE oxygen, quite different from a fire hazard stand point.
<font color="red">2001 F250 XLT CC SWB PSD, White w/silver, 2WD AUTO, PRE-PUMP MOD, X-Monitor from DIS, ZOODAD, PMT2 to MNM1 reflash from Bill @ Diesel Power Chips , SP Power Box ,Walker BTM, Custom open intake, Sonnax/Tricum, DI in-tank mod, Ranger heater valve, FORD AIC, Hella Micro FF, Access toolbox tonneau, 4 position chip from Diesel Innovations </font>, and two German Shepherds hanging out the rear windows Truck pics
Just the same I dont feel safe with pressurizing a barrel of methanol.
At 15psi of pure oxygen, as in the Apollo 1 fire, aluminum burns.
I just dont want to have an overflow of an alcohol all over my shop floor.
None of us do. What happens when the seals give out on the hand pump we are using?
I would venture to say with some speculation on my part, that a pump made for methanol, hand/electric/air powered or what ever would be way more than I would want to spend.
For a real safe way to despense it, use a barrel rack that you tip to horizontal when despensing, then stand it back up when storing.
I have such a rack just takes up to much room.
Rick H...
HIS
HERS
I'm going to talk with my methanol supplier tomorrow what they use for methanol barrel pumps.
I figure better safe than sorry.
