BD Seperation leaveing a visible "slime"? Does this happen? - Diesel Forum - TheDieselStop.com
Old 12-13-2008, 11:00 AM   #1 (permalink)
If a b5 or b20 were to separate in the tank, what would one suspect the reason could be and what would the fuel look like if it were to separate? This thread goes with one I posted earlier. In addition to a "slime", the fuel has a difficult time pumping out of a 18gpm pump, to the point I think I could pee more than what is pumping. For a temporary, about 3 days temporary, we have had success using the additive 911. The additive seams to allow the "slime" to remix or blend giving a somewhat normal appearance to the fuel. The fuel is a yellowish color and when the "slime" is remixed it then has a cloudier haze but still yellow. By the way, why is it yellow? I thought on road fuel was a blueish color.
indychad is offline
Old 12-15-2008, 10:13 AM   #2 (permalink)
If it's seperating because of the cold it can do what you're saying i believe. The BD drops out this waxy type stuff and it doesn't mix back in well. Depends on the fuel and feed oil too I believe...
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 12-16-2008, 11:20 PM   #3 (permalink)
Is the biodiesel purchased or homemade?
Do you know what kind of oil it's made from (ie canola, chicken fat, palm oil, soy, restaurant grease, etc)?
how cold has it been?
If it gets c old enough to freeze the biodiesel portion of the mix, it can do what you're describing and that's a cold flow issue that's caused by the type of oil, not a real quality control problem. Quality control problems (like soap in the oil, or poor conversion) can also cause this, but sooner in terms of temperature (ie at higher temps than the same oil of converted properly and cleaned properly afterwards).
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
Old 12-19-2008, 10:31 PM   #4 (permalink)
kevinj1's Avatar
My mix also has what looks like some sort of fall out. Will it hurt anything to run it or do I have to stop running biod. for the winter?
Central, New York
2002 F350 CC,SB Dually XLT, 7.3 Auto, 4X4,102k mi
ZooDad, NAPA 6637,Walker BTM, DIY WVO system '08 mirrors, Much more do
Towing 2011 Flagstaff 8528 BHSS approx 9200 lbs
2001 F-250 7.3L PSD Auto 4X4 SOLD
kevinj1 is offline
Old 12-20-2008, 02:50 AM   #5 (permalink)
no, don't run biodiesel with frozen stuff falling out of it. It'll clog filters.
girlmark is offline
