Best engine and tranny setup for running WVO? - Diesel Forum - TheDieselStop.com
Old 10-18-2008, 12:22 PM   #1 (permalink)
I'm just starting research in this. I have searched the threads and have gotten some ideas on the peoples likes. However, i don't own a diesel, and i'm in the market to purchase one. I would like to get the best bang for the buck. If you could start over, what setup would you run, and why? Any suggestions would be appreciated.
Just i case people ask, i drive over 200 miles a day, mostly highway. Tow a boat during the season, and trailer for hunting. I live North of Atlanta, and the temp rarely goes below freezing.
rich
richierich69 is offline
Old 10-18-2008, 05:25 PM   #2 (permalink)
luckuslucas's Avatar
Get a 1994-1998 Dodge with the 12 valve Cummins and a 5 speed. Your next best option would be a 7.3L Powerstroke.
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'96 International/Bluebird school bus, DT466, homemade WVO system, www.thebiggreenbus.org
'04 Jetta TDI, Greasecar WVO conversion (chases the bus around the country)
'89 MCI 102A3, Detroit 8V92TA, Frybrid/Rover Hybrids custom system
luckuslucas is offline
Old 10-20-2008, 05:35 PM   #3 (permalink)
airfooter's Avatar
Do you have a source for WVO? It is getting very hard to find in your area. Whatever you do, don't steal it. Theft has really cast a negative shadow on us. Unless you'd like to be harrassed by cops for driving around w/a barrel and a pump in your truck - then stealing is OK - as long as ya don't mind when the guy who owns the oil catches you and.....
If you do the Ford, get a 7.3 PSD - '99 and up are better. If ya want more than x-cab, ie - crew cab, you must get a Ford. The DFA Vegistroke V3 is the only conversion to consider. The others are junk adapted from 'traditional' diesel engine design 'retrofitted' (poorly I'll add) to the unique PSD injection system.
If ya get the Cummins, you'll want the Frybrid conversion system.
Listen, YOU especially are going to get your money back from a 'good' conversion. Don't cheap out and get some crap thats gonna leave you on the side of the road (if ya make it that far). It will invariably fail in the cold, while its raining and yer in a hurry takin' the grumpy mother-in-law to the airport. The DFA and Frybrid systems are bar-none the highest quality products your money can buy. They WILL work, the first time, without issues - and Frybrid systems operate SVO in -45 deg weather (DFA should go below 0 no problem).
Happy hunting! Good luck!
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline
Old 10-21-2008, 12:25 AM   #4 (permalink)
ajohansson's Avatar
Listen to what Airfooter (jason) is telling you. I went for a GFS conversion just for the excursion tank (no one else was makin them then) and had to learn the hard way about how bad my system was plumbed. I relied on all of these guys on this forum and frybrids to get me back running again. It took 2 months of working a few hours every other night to get my truck plumbed the right way and its still not a vegistroke. Its good but not perfect. Spend the money up front on either a frybrid or vegie stroke. I would do some heavy looking into getting enough oil to go your200 mile a day habit. It is getting harder and harder to secure sources. Nothing worse than ivesting 4k into a system and then cant find any oil.
AJ
ajohansson is offline
Old 10-21-2008, 06:58 AM   #5 (permalink)
setup
I do have a source (Hooters) for the WVO. I could possibly have a (chik-fil-a). I'm figuring 50 gallons a week, 200/month. Airfooter, you live where in the mountains?
I have heard that the Cummins is the bulletproof seup, with some modifications ie dowel rod, and fifthband. The problem comes in finding one around here. The F250's are pretty easy to find, but the manual Dodge.
Thanks for all your help, i'm looking at a 97 Cummins this weekend, and could be ready to get the frybid by the first of November.
rich
Old 10-21-2008, 11:29 AM   #6 (permalink)
99-03 7.3 PSD and a John Woods or BTS tranny
Stefan, 2000 F 250 CC 4x4 PSD SB, Weld Wheels, 35" BFG AT's, Line-X'd, Ride Rites, Auto Meter Guages, Leer Shell, Rancho Lift & Chipped,
1993 F 350 SC 4x4, Banks Sidewinder, Eagle Wheels, 35" BFG AT's
Truck, Hunting and Fishing Pics
Stefan is offline
