bio compatible gasket maker? - Diesel Forum - TheDieselStop.com
Old 01-23-2009, 11:37 AM   #1 (permalink)
Does anyone know of a gasket maker or sealant that is Bio-compatible? or even better yet an epoxy?
Brad
96 F-250 extended cab long bed, 5-speed, Luk clutch, 4x4, 4.10, 3" lift, 35x12.5 BF All-terrains, 3" down pipe, straight pipe, shimmed FPR with gauge, stage 1 injectors, Dp-Tuner F-5 80 econ. 1100 HI-Idle 100HP Performance, Gauge style switch, ISSPRO pyro and boost, water temp, oil pressure, SuperDuty starter. 193,000 and counting
blaster1288 is offline
Old 01-23-2009, 02:48 PM   #2 (permalink)
I bet JB weld would be okay. I can tell you silicone seal doesn't work at all though. It'll be through that in a few hours...
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 01-24-2009, 11:16 AM   #3 (permalink)
I don't think JB weld would adhere to plastic. (need to adhere to plastic if i forgot to mention). JB will adhere to PVC but it doesn't mention anything about general plastic.
Brad
