Bio- diesel refining using waste Methane gas ????? - Page 2 - Diesel Forum - TheDieselStop.com
Old 04-01-2006, 10:56 AM   #16 (permalink)
Re: Bio- diesel refining using waste Methane gas ?????
I was just thinking that a decent sized compost facility, properly layedout and plumbed could add asignificant amount of heat to a small commercial biodiesel facility. At a minimum heating the workspace and warming WVO stock in coold climates. I was envisioning insulated with radiant heat lines in the base slap, a roof of some sort, etc. I've seen somea large faciltities. Feeding the piles with some glycerin would kick up the reaction a bit too. An anaerobic digester is different monster all together.
It has been done and they report that the liquid returning from the pile is over 120 deg f.
I can not find the link, dangit, just looked at it last night.
If I find it I will post it.
Basically, the set up 4 55 g barrels at different elevations, pump water from the building out to the highest barrel and allow gravity to feed from barrel to barrel the nback into the building. All the barrels and piping are under the compost pile.
They were using WVO instead of water but due to a fire inside the pile, the switch to water.
They had seeded the mulch pile with fertilizer when building it and got to much of a concentration of fert in one place on a peice of pvc pipe, which metled the pipe and ignited.
If I only had the room, heat WVO, heck heat the house!
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
