Bio-Diesel use in a 7.3 issues? - Diesel Forum - TheDieselStop.com
Old 12-24-2008, 09:10 PM   #1 (permalink)
Hi,
My RI fuel dealer sells:
On road diesel
B-20
B-50
B-99
I asked a Ford dealer in Maine about using Bio and they said the 7.3 can run it without problems. I've never used the B99 but a friend of mine w/ an F350 7.3 does. I've run the B20 and it does get hard to start when temps drop to 35 or so. Then I run regular.
Any feedback on it's use?
My mechanic in Munich said DON'T use it in the Mercedes OM-352A diesels. Dey vil becom kaput!!!
Chris
2002 F450
unimogr is offline
Old 12-24-2008, 09:20 PM   #2 (permalink)
F350_6's Avatar
Bio has a MUCH higher gel point than regular diesel. I believe B100 is somewhere around 40 F depending on feedstock, so this time of year it can be a problem. Summer months you can run the B99 with no issues at all (unless you have a dirty fuel tank, in which case it will clean the junk out and plug your filter).
Talk to your local supplier and see what type of dino diesel they are mixing with the bio, and what additives (if any) have been put in. Find out if they know the gel point for each grade of fuel and make your decision based on as much info as you can find. If nothing else, stick 12 oz in a coke bottle and leave it out overnight to see if it gels.
Chris
2002 F350 6-speed 444 CID. XLT, Heated Seat, 393,000 & counting.
“Good judgment comes from experience, and a lot of that comes from bad judgment.” Will Rogers
F350_6 is offline
Old 12-26-2008, 09:02 PM   #3 (permalink)
Oh yeah. We had a Bobcat 863 with tons o crud in the tank. Finally had enough, filled w/ B50 twice, cleaned out the filters a number of times and life is now good.
I was more concerned about incompatibillity with rubber/plastic internal parts etc. I was also told not to run it in the newer than 7.3 diesels.
Chris
2002 F450
unimogr is offline
Old 12-26-2008, 10:20 PM   #4 (permalink)
kevinj1's Avatar
I have been running B100 or some percentage blend with dino fuel in the truck in my sig. for 13K miles other than a few clogged filters and once gelling @ 4*F. if its quality fuel you will be fine. in your truck.
Central, New York
2002 F350 CC,SB Dually XLT, 7.3 Auto, 4X4,102k mi
ZooDad, NAPA 6637,Walker BTM, DIY WVO system '08 mirrors, Much more do
Towing 2011 Flagstaff 8528 BHSS approx 9200 lbs
2001 F-250 7.3L PSD Auto 4X4 SOLD
kevinj1 is offline
Old 12-28-2008, 09:07 PM   #5 (permalink)
Ragdude's Avatar
I have been running 100% bio for over 2 years now, and just recently had to replace fuel lines and fuel pump (in my '96) I'm sure due to the bio, but at 185,000 miles... not so bad. Thankfully here in Phx., gelling is not a problem.
Protect the 2nd Amendment!
It's the original homeland security act.
'96 F350,Dually,CC,5 spd.,stock.
'02 Excursion Limited, stock
B100 baby! Bring it home, to the American farmers!
Remember 9/11, and don't become complacent again
Ragdude is offline
Old 12-30-2008, 10:55 PM   #6 (permalink)
luckuslucas's Avatar
Originally Posted by unimogr View Post
Hi,
We have a couple older Pisten Bully snowcats with that exact same motor, and while we haven't run any of them on biodiesel yet, I find it hard to believe it would kill them. Those are tough engines (we've got one with 10,000 hours on it) that get worked hard, so I can only imagine some high lubricity fuel would make them happy. We've got a spare engine, and my dad and I are playing with the idea of a WVO generator...
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'96 International/Bluebird school bus, DT466, homemade WVO system, www.thebiggreenbus.org
'04 Jetta TDI, Greasecar WVO conversion (chases the bus around the country)
'89 MCI 102A3, Detroit 8V92TA, Frybrid/Rover Hybrids custom system
luckuslucas is offline
Old 01-01-2009, 11:16 AM   #7 (permalink)
I'm running the risk of going off topic but the OM-352 (& the A & LA) are the most highly produced diesels in the world or so I'm told. They're produced in a number of countries, Germany, Turkey and Argentina, and in variations from 32 hp for stationary applications to 350+/- for marine all using the same block.
I've seen these engines in Unimogs with 12,000 hours still running well. Mine has 24+/- hours so I should be good for a while.
My dealer in Munich, Schussler told me they see problems w/ trucks running Bio. I assume it's home brew vs. store bought (is there a difference?) but I run B-20 in the summer and so far it runs great and the fuel tank is shinny clean inside. I need to talk to the guys at Boston Fuel Injection to see if the Bosch model W pump would have compatibillity issues.
I worked at King Pine Ski Area in NH and they had 2 Pisten Bullys but the Prinoth w/ a Cat was my favorite.....
Chris Elliott
F450
U-1300L
unimogr is offline
Old 01-05-2009, 02:40 PM   #8 (permalink)
the 7.3 Powerstroke is one of the best engines in recent years, shouldn't have any issues with biodiesel other than gelling in cold weather. The best way to prevent gelling is to familiarise yourself with cold testing- take a sample, put it into a small jar, and freeze it. The temp at which it starts to look cloudy is the temp at which it may clog filters (the clouds are small frozen crystals of biodiesel).
To deal with gelling issues, you can get a filter heater that increases the range of temperatures at which you can run the fuel, you can blend a lot more diesel in in the winter, you can use zero biodiesel in the winter, or you can try some other modifications. If your fuel is made by the producer out of animal fats, poultry fat (really common source these days), palm oil, or some other fats, then the cold filter plugging point will be worse than if it were made out of soy, corn, canola, or other 'liquid' oils (the fats biodiesel is fine in summer and it has some other advantages (higher cetane for instance) over liquid oils, but they're not big enough to worry about in warm weather).
I'm not sure which 7.3 you have:
The 7.3 Powersmoke does well on SVO with an SVO conversion also. It's one of the most stable old truck diesels for SVO conversion. Hold on to this truck, I wish I had one instead of a GMC right now.
The 7.3 IDI has a couple of issues:
-works fine on biodiesle other than the same gelling issues (same solutions apply, in fact, one of my old 6.9's had a built-in 12V fuel preheater right before the filter and I never gelled in a mild climate where our winter only hit 40's whereas some other users did experience cold filter plugging)
-for SVO conversion they're more finicky., They had the crappy Stanodyne injection pump that doens't like SVO's higher viscosity and occasionally seizes in that application. I'd be prepared to replace pumps and be very careful about SVO conversion and monitoring of system temperatures if I were trying to convert one of these to SVO.
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
Old 01-29-2009, 11:52 AM   #9 (permalink)
Spencnaz's Avatar
My Photos: (14)
A couple of issues with the 7.3 you need to be mindful of.
1. Keep the oil clean. Change that oil every 3-5k miles religiously. The injection system uses oil pressure to activate the injectors themselves. Dirty oil will either hamper or clog the injector system.
2. The CPS (crankcase position sensor), these can go out but are very easy to replace. Many chain auto parts stores will have them in stock.
3. If you have a '96 or earlier, be mindful that the revised and increased the size of the glow plug timer/controller that sits on top of the engine. The early models had this little wimpy looking thing but was later replaced by a much more substantial glowplug relay. If you can, upgrade to the newer relay.
4. Injector pressure: since these engines run a direct injection process, the injection pressure is going to be much higher than an indirect injection process. Be sure that the biodiesel or WVO you plan on using is very very clean, even a speck of trash can ruin an injector.
Hope these little tips help. Personally, I like the 7.3 but I've never been a fan of engines with computers on them, I like to keep things simple.
If my 6.9 gives up on me, I may consider getting a 97-99 Powerstroke.
Spencnaz is offline
Old 02-01-2009, 12:07 AM   #10 (permalink)
My Photos: (17)
Should be no difference as long as both were made and washed correctly.The only difference would be gel point due to feed stock difference.I have been running home brew in my 1999 E300TD for 30k plus and have not clogged a filter yet and only have changed it once.The only issues with the pump would be with the seals I would think.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline
Old 02-01-2009, 09:26 AM   #11 (permalink)
airfooter's Avatar
I agree the PSD is fine w/B100. I have been having issues w/B100 in my SVO-converted truck though. The problem is while I'm burnin' VO, the B100 is just sitting in the filter bowl on top of HOT engine (ie, towing 5ver thru Rockies) for hours and hours at a time. I started plugging diesel filters (did this a couple times when first running bio - like everyone else) and finding polymerized biodiesel in the filter housing!!! No, there is no way for VO to get in my diesel system - it was from the bio-d.
'Commercial' bio-d should have some 'fuel stabilizers' in it to mitigate this natural breakdown of the VO part of it. But, allegedly none of the B-99 available 'at the pump' still meets the stability part of the ASTM standard, indicating they still don't have it down yet.
On the same subject, Bosch has issued reports recommending no more than B-5 in any of their IP's. They have found evidence of polymerized bio-d in many of the IP's that failed after running higher concentrations of bio-d. That said, obviously MANY folks have had great success running B100 in IP-equipped engines. But, if you're a vendor for auto manufacturers and ya have to warranty your parts - you just recommend what you KNOW is less likely to cause problems.
Like the others said, gelling is directly related to feedstock. We try to segregate our 'lightest' VO for bio-d. We look for VO that is still liquid well below freezing and save that for B100... I use the coke bottle/water bottle trick for every batch of 'winter' B100. If the little bottle gells, I know I need to add some diesel.
BTW, its good to see a post from girlmark! Hows that cheby working for ya?
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline
Old 02-16-2009, 04:19 PM   #12 (permalink)
Rickie's Avatar
Chris
2002 F450
A few years ago, the two major German industrial diesel engine manufacturers (Deutz & Mercedes) recommended a maximum bio-blend of 5% AND that the bio-diesel had to be rapeseed-based (canola & camelina are types of rapeseed). Their testing (in Europe) showed that rapeseed-based bio-diesel was the "best" quality and that soy-based bio was inferior. Since the majority of North American bio-diesel is soy-based, you can see why the mechanic in Munich said what he did.
We've been running B70 since June '07, B50 for the year before that, and B20 in most of '05 in +300 pieces of equipment without any major issues (other than one tanker hose that was standard rubber). The Bosch-style high pressure fuel rail systems have had no problems. Our Deutz & Cummins engines run similar systems and are the majority of our engines.
'00 F250 XLT 4x4 (born on 6/00), manual tranny & hubs, SPA Techniques EGT/Boost Gauge, Homemade HX Crossover Mod & Return Fuel Regulator, Toro Liner, 203* T-stat and Coolant Filter, LUK Clutch, flywheel & pressure plate, Amsoil Dual Bypass Filter
Rickie is offline
Old 07-03-2009, 12:43 PM   #13 (permalink)
Have a happy 4th July Y'all
My Canola oil experiment. I'm getting used Canola oil that spends about a month in a deep frier making french fries and onion rings. The cook does not uses hot water to flush out the deep frier so I don't have to seperate H2O.
Have added 4 1/2 gallons of filtered canola oil to the front tank's 12 gallons of diesel with no negative results yet. When running mix motor seems not as loud.
I start and shut off the the motor with the rear tank with 100% diesel. I do not switch over the the mix till the till the motor warms up and switches back to rear tank. I filter the canola into a large glass jar so I can see the oil. Do not plan to use canola oil in winter.
You tube has a bunch of videos of people runing older diesel motors on 100% vegi oil.
Check out myth busters on you tube.
Will keep forum posted on my results.
White, 1996, F250, XLT, 4x4, 7.3 PSD, Garrett Turbo, Supercab, 8' bed, home made goosneck hitch, 257,876+ miles, Rotella T synthetic 5w-40, Motorcraft filters, BG synthetic trans fluid, two Haynes 1405 transmission fluid coolers.
okiephillip is offline
