bio-diesel or waste Trans fluid - Diesel Forum - TheDieselStop.com
Old 01-16-2013, 04:54 PM   #1 (permalink)
Hello again,
I have a question and hope you guys could help.
I have a good supply of WVO and have started making micro batches of Bio and this is going good. Here is my delima I can get a almost endless supply of Trans fluid.
Would you stop the bio production and use the trans fluid or can I use both?
What are your thoughts.
1988 f-250 4X4 6.9 one good running rusty dog..
theindianabricklayer is offline   Reply With Quote
Old 01-16-2013, 05:15 PM   #2 (permalink)
My understanding is that you can't use both. WVO and any WMO product when mixed produce a glue like substance that fouls your entire fuel system and turns into a porcelein like product when burned. If you have an unlimited supply of transmission fluid, that is where I would go. But then again, I use WMO so listen to what others have to say. Just stay away from mixing the two.
Jerry
2000 F250 Superduty 180K and counting 4X4 4R100 Glow Shift gauge - EGT - Boost - Tranny Temp Fuel Pressure on an A pillar mount Diesel Site boots Transgo shift kit K & N Stage II air filter 5" exhaust RiffRaff AIH to boost mod CCV mod DP-Tuner with W85 settings Amsoil Bypass oil filter 6.0 tranny cooler, W80, Cooling Mist water injection.
F250Truckin is offline   Reply With Quote
Old 01-16-2013, 05:28 PM   #3 (permalink)
badbart's Avatar
Good info on not using both. Pretty much a no-brainer. All you have to do with the transmission fluid is filter it. Not a lot of labor in that. A friend has been using tranny fluid for years in his 7.3. He says he has to mix more diesel with it in the winter months. Hey, free fuel....I'm envious....
1997 F350 XLT Crew Cab Dually, 7.3 Powerstroke, 4:10 limited slip, K&N Air Filter, MBRP 4" Turbo back w/muffler, Edge programmer, Billet torque converter, Monster tranny cooler.
2004 Cadillac CTS V 5.7 LS6, Tremec 6 speed,
K&N Cold Air, Magnaflow Exhaust, MSD Ignition,
LS7 clutch, Getrag 3:73 posi-trac, 377 RWHP
badbart is offline   Reply With Quote
Old 01-16-2013, 06:11 PM   #4 (permalink)
bio-diesel VS trans fluid
Ok, Once I stop using bio-diesel . How may tanks of diesel to flush the system? Any ideas?
Old 01-17-2013, 06:07 PM   #5 (permalink)
I don't know on that one.
Jerry
Old 01-17-2013, 06:48 PM   #6 (permalink)
I wouldn't bother flushing it. It'll mix and get run through the engine fast enough it won't make a mess in the tank.
You could run it near empty, then just switch to your new fuel.
'92 F350 crew cab, dually, 7.3L, ATS088 turbo, Moose pumped, bb coded, e4od, 3.55 gears, 2wd
'Fuging free WMO fuel with a WVO Design Extreme unit
Blind DrIver is offline   Reply With Quote
Old 01-17-2013, 06:56 PM   #7 (permalink)
badbart's Avatar
I guess you missed that second post....
Old 01-18-2013, 02:20 PM   #8 (permalink)
Blind Driver is probably right . Just to be on the safe side I would run a tank of D2, change the fuel filter & then run tranny fluid.
If you have a good supply of WVO coming in I would NOT give it up. I would keep collecting it, put an add on Craigslist & sell it. If your tranny fluid supply ever dries up you still have WVO coming in.
You have the best of both worlds. Don't give either of them up.
2001 F-350 Nondually. 192K miles. Pretty much stock. DIY SVO Vegistroke style 2 tank conversion April 2010. 70K miles On Vegi!!
simone0414 is online now   Reply With Quote
Old 01-18-2013, 05:37 PM   #9 (permalink)
After you run the D2 through it, be sure to change the fuel filter.
Jerry
