Bio in new Trucks - Diesel Forum - TheDieselStop.com
Old 10-09-2008, 04:38 PM   #1 (permalink)
biofumes's Avatar
Bio in new Trucks
If biodiesel is so much cleaner and better for the environment and has better lubricity for the injectors, then why are all the truck manufactures only covering our warranties with a B5 blend?
I have a Ford , and what they are saying is that biodiesel could cause mechanical failure if more than B5 is used. Even though you purchase it from a commercial producer and meets the ASTM standards??
Model years 2003 to 2008. Does anyone know why??
biofumes is offline
Old 10-09-2008, 05:08 PM   #2 (permalink)
No I dont.
I do know that Ive ran a lot of B99 through my 2002 and 2003 7.3's
and the place I used to get biodiesel from had 2 08 F250's when they first came out...and they ran B99 as well.
- Shawn Collister #16 ATV MX -
- Tampa Florida United States of America -
-2002 F250 Crew/4x4/Auto- AIS, 4" Magnaflow, scan gauge, Vegistroke V3
-2003 F450 Crew/4x4/Auto/4.56 rear- 4" MBRP, Alcoas, Air ride, AIS, Garrett BB, X monitor
Tampa550 is offline
Old 10-10-2008, 11:49 PM   #3 (permalink)
biofumes's Avatar
Originally Posted by Tampa550 View Post
No I dont.
Well I thought there would be some retired ford techs in here? We all know it will burn and work, but what are they so terrified about that they void warranties??
biofumes is offline
Old 10-11-2008, 04:04 PM   #4 (permalink)
6.0L will have zero problem, 6.4L might have a problem due to regen cycles but even then it's a minimal problem.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 10-12-2008, 04:32 PM   #5 (permalink)
My Photos: (17)
I have a Ford , and what they are saying is that biodiesel could cause mechanical failure if more than B5 is used. Even though you purchase it from a commercial producer and meets the ASTM standards???
The only thing I can think it could be from would be mosture in the fuel. At the high presures that the new diesels run I had read that bio can do some weird things when there is mosture in it.Like turn to a plastic substance.I would like to hear from them the "auto makers" what there concerns are and what failures they think will happen.
If you have any failure that could be blamed on fuel, diesel or Bio they would not warranty .
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline
Old 10-15-2008, 01:07 AM   #6 (permalink)
Its not the auto maker, its the inector makers.
Biodiesel VS. Your Warranty - Diesel Power Magazine
The problem lies in loose or non-existant standards, and the ease of home-made w/out good QC. they can't control what we pour into our tanks (just take a look at what some here are burning), and they don't want to be stuck with a warranty claim.
BD is a great fuel, but it needs care in manufacture and storage to be used properly.
Just remember, Ford won't warrant a repair if you get bad #2 either.
OMC
OMCUSNR is offline
