Re: Biodiesel and the 6.4
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">So I finally got my answer back from Ford on biodiesel. If you use more than B-5 (and good luck determining what any particular station has at any given time) your warranty will be voided for any problems that they determine were caused by fuel. It was like pulling teeth to get this out of them, but that was the answer.
</div></div>
That was in my 03 diesel supplement, too. Its pretty much what the injector manufacturer's are saying they'll cover.
The thing I think many of us forget, is Ford doesn't cover "bad fuel" at all. If we get a bad or dirty batch of #2, and it causes problems, Ford will deny coverage - take it up with who sold you the fuel. Includes ATF, Alcohol, UMO, gasoline, bio "blends", diesel secret, kerosene, jp-5, jet-a, crude & bunker oils, etc. If any of those are present in the "fuel" Ford has the right to deny coverage.
