biodiesel blend for 6L??? - Diesel Forum - TheDieselStop.com
Old 07-29-2004, 09:49 AM   #1 (permalink)
My Photos: (9)
Hey All,
I have been doing some reading on biodiesel, and was curious as to the biodiesel blend for the 6L, I remember reading somewhere that is was B5 or B10.. Someone please correct me if i am wrong.
'05 F-250 Harley-Davidson, 4x4, 6.0L, True-Blue, completely loaded with every possible option.
Motorstuff: NONE
'04 F-350 CrewCab FX4 DRW 6.0 2-Tone Black/Silver
Motorstuff: NONE
***TRADED-IN***
koolkat812 is offline
Old 07-29-2004, 11:52 AM   #2 (permalink)
Re: biodiesel blend for 6L???
Auto manufacturers do NOT warranty damage caused by fuel. Ford and the other diesel engine users have posted that they will officially OK a blend of up to 5% bio diesel. However, the engine will run on 100% bio-D. BUT, if you have probs, and Ford blames it on the fuel, your out of luck, you'll have to go after the fuel manufacturer for repairs. Ford is just trying to cover their butts, and still give the semi-OK to run bio-D.
This is nothing new really. If Texaco sold you gasoline that was 50% water and it hydrolocked your small gas engine, you would go after Texaco, not Ford for the repairs.
So long as the bio-D meets ASTM standards, you can run 100%.
Ford_Forgotton is offline
Old 07-29-2004, 11:56 AM   #3 (permalink)
My Photos: (9)
I just read on the dieselmann's page that ford will allow bio-diesel up to 5%. And I have found a place here that sells it for 2.15 a gallon.
So I guess time to try it out, and see how it goes. I will get a reciept stating the 5% blend of bio-diesel just to cover my a$$.
BTW: Have you tried biodiesel, and what were the results
Motorstuff: NONE
Motorstuff: NONE
***TRADED-IN***
Old 07-29-2004, 03:11 PM   #4 (permalink)
The effects of bio-D increase with the percentage. B-20 is usually the preffered mix, but there is nothing wrong with b-5.
Advantages is that bio-d is a fuel system cleaner. If you have any junk in your tank or line, the bio-d will flush it to your fuel filter. So if you plug a filter, thats why. Problem goes away once your system is completely cleaned.
Im not running Bio-D as I cant find it in quantity here in New Orleans, so Im in process of making my own.
In the mean time, I just pour a gallon of new virgin oil in the tank whenever I fill up. That gives me about a 3% mix of oil to fuel with a 29 gallon tank.
Old 07-29-2004, 04:57 PM   #5 (permalink)
Where are you buying your new virgin oil? Cost per gallon?
Thanks, KC
2000 F250 V10 CC 4x4
Photos
Havasu6 is offline
Old 07-29-2004, 11:56 PM   #6 (permalink)
Forgotten, what happens to coke buildup on injector tips? Has anyone heard if biodiesel will clean the coke from injector tips?
Koolcat, I burned my first half gallon brew of biod in my 04 6.0, adding it to about 3 or 4 gallons? 1/8 tank of dino diesel remaining in the tank.(That is somewhere near B15) It quietened down a good bit and had no problems! When I filled up with dino, it got loud again...
PS So far, I have approached 3 mom/pop restaurants about their oil and all have said I could have all I want! A fourth one gave me 5 gal for our test batches and probably would give me all I want but I didn't ask yet.
'05 F250 4x4, CC, 3.73 LS, auto, FX4 White over Arizona Beige - Lovin this one! Just got back from DC, got an incredible 22.87 MPG @ 65mph!
***Bought back DSB 11/04! 03'04 F250 4x4 Crewcab, 3.73 gears, auto, FX4
Calculated unloaded average MPG since new to 17k miles: 13.8 [img]/ubbthreads/images/graemlins/frown.gif[/img]
83 E150 - 300-6, 92 E150 - 300-6, 93 E150 - 302-V8, 93 Dodge 250 Van - V6(Don't buy one of these!)
FTG5 USN, '84
teester is offline
Old 07-30-2004, 08:37 AM   #7 (permalink)
My Photos: (9)
I found a place here in FL, that will provide the blended B5 that ford suggests we put in these things. Its about 2.15 a gallon, I am looking to try it and see how much better my mileage gets. On the highway this thing is awesome but in city traffic (stop and go) it sucks... especially during rush hour.
Motorstuff: NONE
Motorstuff: NONE
***TRADED-IN***
Old 07-30-2004, 09:10 PM   #8 (permalink)
Koolcat, I wouldn't look for better fuel mileage as Biodiesel has a little less MPG than dino. [img]/ubbthreads/images/graemlins/frown.gif[/img]
FTG5 USN, '84
teester is offline
Old 07-30-2004, 11:40 PM   #9 (permalink)
I run 5/38 = B13 on a regular basis. No problems found
OMCUSNR is offline
Old 07-31-2004, 12:30 AM   #10 (permalink)
Thanks, KC
I only do it when I find cheap oil at the grocery store, nothing fancy, not every tank.
Old 08-02-2004, 11:51 AM   #11 (permalink)
I'm doing the same thing. Veg oil is significantly less expensive than Lucas Fuel Treatment and I think I'm getting simular results, the injectors are certainly quieter. Currently adding a quart or half gallon per tank of diesel.
Photos
Havasu6 is offline
Old 08-03-2004, 02:46 PM   #12 (permalink)
I've found that when running B20 winter blend, my mileage is about a 1/2mpg less than winter blend dino, but when running the B20 summer blend, I'm up 1 to 1.5 mpg over summer blend dino. And that's with using my new Diesel Turbo Lifesaver, so my truck is idling a lot more this summer than it did last summer.
Some of that may be due to the local producer's updated Bio formula that they've been claiming will increase mpg. I figured "yeah, whatever [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]", but so far my mpg is up 1 to 1.5 mpg over what I was getting last summer and recently on regular diesel. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
bandit67 is offline
