Has anyone here made a biodiesel processor from a water heater?
It seems like a pretty good idea and there are some good pictures of setups on the net.
I made mine from a 50 gallon water heater. It will make about 38 gallons max time you add 20% methanol and leave a little space for splashing around a bit.
I used all stainless valves though, which made the cost around $400 or so I think. Brass valves will turn a nice shade of green inside when exposed to wvo. I changed the valves on my tanks to stainless also. Don't want anything in my fuel but fuel!
'05 F250 4x4, CC, 3.73 LS, auto, FX4 White over Arizona Beige - Lovin this one! Just got back from DC, got an incredible 22.87 MPG @ 65mph!
***Bought back DSB 11/04! 03'04 F250 4x4 Crewcab, 3.73 gears, auto, FX4
Calculated unloaded average MPG since new to 17k miles: 13.8 [img]/ubbthreads/images/graemlins/frown.gif[/img]
83 E150 - 300-6, 92 E150 - 300-6, 93 E150 - 302-V8, 93 Dodge 250 Van - V6(Don't buy one of these!)
FTG5 USN, '84
Is the green from the wvo or from your bio I was told that bio is very nasty to hoses and you have to use viton because it will eat regular rubber hose.This was from a locale hose supplier who is trying to get hose for bio installs.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
Hey guys, mine is for sale! I am building a 250 gal processor as I plan to replace my work vans with diesels. Making a huge batch will dramatically lower my "hands-on" time. Last 30 gallon batch, including oil pickup, cooking, and washing was probably about 2-2.5 hours.
I built my 50gal unit to see how practical it was. Now that I know how little effort it takes, how much I am helping the environment, not contributing to terrorism and how QUIET my truck is with the stuff, I am going full speed ahead! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
FYI, it has all stainless valves and methanol still on top. Will make about 38 gallons. If interested, pm me.
FTG5 USN, '84
Is it true that with a Hot water heater setup the process can be done in 1-2hrs because the heat speeds up the reaction?
Sure would be nice to take a 80gal heater and make some large batches [img]/ubbthreads/images/graemlins/grin.gif[/img]
Yea, you can make it in less time. Supposedly a 10 degree increase in temp will cut process time in half. I make it at 125-130F and mix for about 40-50 minutes. If I increased the temp to about 145, I could halve the time. However, you shouldn't try to do it above about 140F because methanol boils at 65C or 149F. That is unless you have a pressurized reactor.
That can be done in the water heater but I'm not familiar with what pressure you would need for what temps etc. However, if made with the see-through hoses I wouldn't try to pressurize it over 10psi or so. Wouldn't want a hose to blow out!
FTG5 USN, '84
That's awesome!
I like the idea of requiring less time and using the pump to do all the mixing w/o any fumes. Is the pump most are using a circulator from a boiler system?
Check out the link here and click the "photo-equipment" button and look for the Biodiesel Appleseed Reactor. It has several pages. Also many photos of peoples reactors and equipment are posted there.
The pump most people use is from "Northern Tool & Hydraulics". YOu will find much info and photos of the pump there also.
FTG5 USN, '84
