Bluegrass fuel system info - Diesel Forum - TheDieselStop.com
Old 11-26-2012, 09:58 PM   #1 (permalink)
i have the bluegrass fuel system already. i bought it last may and have put over 5000 miles on my truck through it.
my question for you is have you tried it?
after listening to you all i think i could build a system much cheaper. i am looking for someone who has used it for years or way more miles than me to warn me or encourage me.
Be Blessed all
Rev Jon Lunsford
1993 7.3 idi/ wmo user.
revjon is offline   Reply With Quote
Old 11-28-2012, 12:00 AM   #2 (permalink)
rejon, good to hear from someone that has some experience with the blue grass system.
What is the mix you are using?
Thanks, Tom
gozapper is offline   Reply With Quote
Old 11-28-2012, 11:44 PM   #3 (permalink)
i have been running a 50/50 mix of waste motor oil and #2 diesel. i am about to switch to a w85 mix. i like the bluegrass system. i will continue to use it for the 1 micron filter for sure.
what are you mixing?
if you don't have it don't waste the money on it. there are cheaper ways.
Rev Jon Lunsford
Old 11-29-2012, 10:40 AM   #4 (permalink)
I am interested to know if the beads work in removing the water.
Tom
Old 11-29-2012, 06:19 PM   #5 (permalink)
i have thought about putting them in straight water to see how much it picks up. i know to clean them you are supposed to pull them out of the container and lay them in the sun to dry them out.
spend the money on a centrifuge instead. it takes the water and the junk out and they cost a lot. so spend your money there, in my opinion.
Rev Jon Lunsford
Old 11-30-2012, 07:19 AM   #6 (permalink)
For the same amount of money spend on thier system you can get a centrifuge for less and get better result. The one I am using came with a heater to eliminate the water as the is being clean. I am using PAbio system.
koya is offline   Reply With Quote
Old 12-16-2012, 05:17 PM   #7 (permalink)
I built my own version of the bluegrass system.... saved a ton of money...
I actually built a filtering unit to filter my oil before it goes into my 25 gallon tank... I then throw my magic sack and add 50% #2... I run 50/50 using w85...
I treat a 55 gallon drum with gas and power service and let it sit for 2 weeks until I'm ready... I fill my 25 gallon poly tank with about 12 gallons in the morning and let it sit in the tank all day while I'm at work.. on my way home I stop and top it off with fresh #2... drive to the house and pump it into my tank the next morning works great and cost me about $250
http://farm9.staticflickr.com/8281/7...8395ce37f8.jpg
1999 Dodge Ram 2500- K&N, Holley Black Pump, Vulcan big line relo kit, 4" homebrew exhaust, Rhinolined rockers, On Board Air, WMO @ 50%
iwhitne is offline   Reply With Quote
