Re: BULK PURCHASE SOURCES for Methanol/Sodium Hydroxide ???
for NaOH go to your local hardware store (Home Desperate doesn't count) the type where you walk in and they ask you what you need and guide you to exactly what you asked for. Ask the for Lye frequently used as a drain cleaner Red Devil is the most common brand name ask them what kind of deal they can cut you when buying it in volume.
95 F350 Centurion Conversion Bronco E40D (Crew Cab SRW) 4X4 4.10, Boost, Pyro, & trans temp on the A-pillar, BDP Stage 1 injectors, Open air intake, Dpp Downpipe, TS chip.
