burning waste oil in 6.0 liter - Diesel Forum - TheDieselStop.com
Old 02-09-2008, 11:48 AM   #1 (permalink)
wandering what you need to do or if it can be done can you run waste oil in a 6.0 and what % oil versus fuel.
kjeeonas is offline
Old 02-09-2008, 05:30 PM   #2 (permalink)
FTG-05's Avatar
My Photos: (25)
The first step is to look for and use the "Search" function. Discussed (and cussed) here many times.....
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 02-10-2008, 07:50 AM   #3 (permalink)
filtering is an important issue. You percentage of oil to fuel depends on a few things. Viscosity and the outside(ambient) temperature.
We have run a 90/10 mix in temps as low as 10 degrees but that was with a plugged in truck and one that has a heat exchanger before the fuel filter. Easiest way is run dual tank setup. one tank is pure other is mixed. start on pure and the when up to temperature run mixed. Im actually thinking of publishing some of this info.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
Old 02-10-2008, 10:50 PM   #4 (permalink)
spg
Well filtered to 2 micron or less with no water or other contaminents in it. A 5 to 10% blend should not even be noticed. Some say that it will ruin everything from the injection system to the motor. Others have run it for many miles in 7.3IDI, 7.3PSD and I am thinking many have tried the same in 6.0 motors. Most people who are running it probably just run it and don't talk about it to keep from hearing all the supposed wrong things it will do to there motors. A lot of which comes from those who have never tried it.
2001 International 4700LP T444E 210HP Fuller Six Speed 3.38
spg is offline
Old 02-29-2008, 08:23 AM   #5 (permalink)
Good call SPG... I said it before most naysayers havent even tried it!
But they are entitled to their opinions --- I just say good leaves more for me and the people who are successfully doing it.
Filtering is key and starting slowly as with most anything. Ive only worked with 7.3s and mercedes diesels oh yes and a few tractors . Anyway pm me if you have any real concerns
jski55 is offline
Old 03-01-2008, 04:16 AM   #6 (permalink)
VegasDiesel's Avatar
If you don't want to get your hands dirty or don't know how and need to have someone do it for you, Jason from vegistroke.com is the best. About Us
If you want a push button, no hassle filtration, and then right into your truck, F2F Filtration Units
Finally, from what I've learned here, this is the best bio diese maker out there. Utah Biodiesel Supply - Bio Pro 190 Automated Biodiesel Processor
03' F350, 6.0, Crew Cab, 4" lift,
Amp Power Steps,
Jimmie Jammers.
4" Turbo Back MBRP exhaust,
Adrenaline HPOP from Dieselsite.com.
155 injectors, egr fix, ARP studs, black onyx gaskets, and SCT custom tunes. All from River City Diesel!
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. been down for a long time and finally getting my tranny rebuilt to handle the power...I hope.
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, yadda yadda. Always in the shop.
Yes the girl in my avatar is actually "my girl"
VegasDiesel is offline
Old 03-06-2008, 10:35 PM   #7 (permalink)
Blending Diesel and WVO?
I know that this has been discussed many times before, but I'm still looking for more opinions on blending WVO and Diesel fuel in my 6.0L. I'm trying to put together a filter setup now in order to efficiently filter my WVO. Any suggestions on what blend to run in a stock truck and unmodified tank? Thanks so much folks!
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 03-07-2008, 07:30 AM   #8 (permalink)
I know someone who is running filtered waste engine oil/transmission fluid in his 6.0l . it is blended with jet fuel and run without any heaters..... i believe he is filtering down to 2 micron before it goes in the truck... no problems as of yet, just smokes a little at idle... but the truck runs strong.....
diesel67 is offline
Old 03-07-2008, 12:02 PM   #9 (permalink)
airfooter's Avatar
Assuming the OP is considering WVO,
Do some experiments w/blending samples. Put different ratios in clear bottles (I like gatorade bottles) in a milk crate in the back of your truck. Observe them after a few days, but also observe in different temps, cloudiness being too much VO)
My testing has shown the VO will settle out of the diesel. I have found that Bio-d and VO stay in solution much better. I have a friend who performed these experiments and found even B20 and VO to perform well.
If the VO settles to the bottom, the first drink your truck takes on a cold morning will be VO. Cold VO in a cold combustion chamber. A combustion chamber that has not 'sealed' up yet and allows some combustion gases to bypass the rings. If that gas has unburnt VO in it, your UOA will show it in short order. BUT, if you were to leave the VO contaminated oil in the crankcase long enough, the VO will polymerize and turn all the oil into a gelatenous mess that does not lubricate your engine.
But, like the guy above said, it must not happen to everybody. I just think it happens to ALOT of people who NEVER come back to tell you they made a "mistake" when they gave you advice. I have seen wrecked engines that ran VO, and my opinions are based on that.
I agree about the Vegistroke and Bio-Pro 190. Good solid equipment, install and forget about it. These people have HUGE advantages of research and experience. The bottom line, if you are trying to save money - the Vegistroke kit will save you money in the long run over any other option. Especially if you factor in yer time. The Bio-Pro is as good as they say, put stuff in, push a button, etc. and it makes perfect fuel (from JUNK, btw) every single time. Even animal fats!!
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline
Old 10-18-2008, 01:53 AM   #10 (permalink)
I myself haven't tried it yet. Me & my friend have been arguing about this mercedez diesels issue for a long time
furblog is offline
Old 11-06-2008, 11:53 PM   #11 (permalink)
Originally Posted by jski55 View Post
Good call SPG... I said it before most naysayers havent even tried it! But they are entitled to their opinions --- I just say good leaves more for me and the people who are successfully doing it.
Filtering? How filtering become the solution here? Can you explain your own filtering process? Does it vary from the usual?
dfarah is offline
