Closed Loop Return - Diesel Forum - TheDieselStop.com
Old 11-13-2005, 09:34 PM   #1 (permalink)
Closed Loop Return
I'm curios about using a closed loop return; hopefully someone will have some insight.
I can think of a couple such as closing the loop will increase the fuel temp at injectors; sending it back to the tank really isn't necessary.
Anyone know how much of a temp increase one would yield?
Would the extra increase of temp actually be harmful as far as longetivity on the fuel pump?
I went ahead and closed the loop on my super duty this morning and now after reading some recent posts, I wonder how well my factory pump will do on my current setup.
-Randy
2005 Excursion Limited; build date 09/04. MBRP T-304 Turbo Back Exhaust. Sickening monthly payment.
rcdallas is offline
Old 11-14-2005, 04:52 PM   #2 (permalink)
Re: Closed Loop Return
I would also like to know. I have a 3 way valve on my return but still have it returned, hav'nt switched it to the filter yet, I guess
I'm waiting for something, but I dont know what.
Bob
chopperbob is offline
Old 11-14-2005, 10:22 PM   #3 (permalink)
From what I am coming up with it's probably a mixed issue speculated type thing. That or in layman terms it's a poor mans way of heating the fuel/oil.
I don't have hard apple to apple test data, but I believe I rose the temperature at the stock fuel filter 20 degrees closing the loop.
I am thinking the best way to find out is to actually see if the ford fuel pump has temperature ratings listed for it to determine the longetivity.
I am not sure why a return line even exists, execpt for gelling purposes of adding a little extra heat to the fuel tank.
I think it'd be a good idea to run a 3 port valve (ac-delco brand) on the return; that way when in a hot climate such as Phoenix you can switch it off, or if your in cold Michigan you can switch it on.
rcdallas is offline
