condensation and wmo
i am having a problem with condensation, well im guessing thats what it is because i dont see how it can be anything else.
this past weekend i cleaned my set up and i drained about 2 gal of water out of both of my drums. i took all the oil out of my finished drum and put it back into the non clean drum so i could refilter it. then this morning i went to turn the valve on my non clean drum to see if there was any water in it and sure enough there was. i dont know how much yet because i did not drain it all out because i had to go to work.
is it because my drums are outside? or is it just seperating out of the oil?
anybody have any thoughts?
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
