Old 10-21-2009, 07:28 PM   #1 (permalink)
considering wmo!!
hey guys im cosidering running wmo. i just got few questions about it first, all that has to do done is filter filter and filter than heat the oil and drive right? please tell me otherwise if not and second could it be mixed with waste atf or is it best not to mix? and last what other oils can be used? thanks guys i am on a tight budget and with my work i travel alot, on my dime, and any dimes saved on fuel sure will help alot.
ERIC
97 F-250 Red ext.cab long bed 4X4 junky slush box e4od 4.10 gears no muffler, new power steering pump, vaccum pump, fuel pump, fuel heater un plugged, k&n air filter,water pump (waste oil powered in the works) free fuel nothing like stickin it to the man 210,000 still running strong
67 F-100 Ranger 351 W auto my first truck
93 mazda b2600i auto 140,000
wifes ride 98 lincoln navigator
used to have:
01 F350 psd crew cab 4X4 junky e4od
f350powerstroke01 is offline
Old 10-21-2009, 07:34 PM   #2 (permalink)
ckanderson's Avatar
if you search all your questions will be answered....
2002 F-250 7.3 4x4
1964 Nova 400 w/350
ckanderson is offline
Old 10-29-2009, 05:46 PM   #3 (permalink)
ive researched wmo and im gonna build a filter set up but i still havent seen anything about mixing oils like atf and motor oil. ive seen ratios like 40% motor oil 10% atf and 50% diesel, but what if i had 10 gallons motor oil and 10 gallons atf would it be better to filter seperate or mixed? should i run the oil in truck and when empty run atf or safe to mix? what about waste oil and veggie oil is it safe to mix?
ERIC
used to have:
Old 10-29-2009, 06:51 PM   #4 (permalink)
ckanderson's Avatar
i run a mix of both. probibly 90 percent oil, 10 percent atf and run it as a 50/50 mix in my truck. most of the oil i run is from hondas so its 5w-20
keep in mind im only on my first tank
it smokes just a very little bit at full throttle, but cutting my diesel costs in half is totally worth it.
2002 F-250 7.3 4x4
1964 Nova 400 w/350
Old 10-29-2009, 07:23 PM   #5 (permalink)
The main thing is to filter down to 1 micron or less and to make sure that there is absolutely no water in it.
blackdog006 is offline
Old 10-30-2009, 12:54 PM   #6 (permalink)
airfooter's Avatar
What happened to the posse on this forum who used to preach the ways of WMO and blending WVO?? Likely they found out why its not such a good idea... It usually takes awhile because 'it runs great' - right up to the point that it don't run so great anymore - then its often tooooo late.
That 'little bit of smoke' is your first indication of failure to achieve complete combustion. This is slowing coking up the combustion chamber and ruining your engine. Yep, MANY folks have had 'limited' success burning WMO and WVO in un-modified engines - but it is often short-lived (nowhere near the life expectancy of a 'diesel' engine). Sadly, the horror stories seldom get published. I have personally met several 'blenders' who wrecked engines and never have posted on any forums - but like you, heard from somewhere WMO/WVO was a viable fuel.
I always say Choose wisely or PLEASE post pics of the carnage!!
But, what do I know - I have a 'converted' truck that has over 110k miles and an Excursion w/over 40k miles on straight WVO without ANY problems. Sure, I spent a few $$ on my conversions, but I got that back so long ago I never give it a 2nd thought! And unlike blending, our 3000-8000 mile road trips cost about as much as driving to town... (I've been well over 10k miles on a single tank of diesel)
I'm not cheap - I'm just BROKE!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, LSD, 4.10's NAPA 6637, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, Mobil 1 in trans, t-case & diffs, LUK clutch, Swamps single-shots!!! Vegistroke-inspired WVO system w/95,000 trouble-free miles! DP-Tuner F5 - stock-high idle-40t-60t-80e-100 - Lovin' it!! 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - F5, AIS, Frybrid/V3 SVO conversion that does 100mi/day. 30k flawless VO miles so far!
frybrid.com
airfooter is offline
Old 11-01-2009, 09:27 AM   #7 (permalink)
firemediceric's Avatar
I'm still doing it
FWIW, three and a half years later from when I began I'm still blending in the two vehicles in my signature.
1999 F-350 and 1981 Mercedes 300 SD. Both running a single tank WVO blend.
Truck: Tymar type intake, Zoo Dad, muffler delete, CCV mod, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil Guard by-pass, Scan gauge II. Loving veg. oil
Mercedes: Installed a Goldenrod fuel/water seperator and injector line heaters. Also loving Veg oil for fuel.
firemediceric is offline
Old 11-04-2009, 08:27 AM   #8 (permalink)
My recomendation is to invest in a centrifuge. This is the path that I took and I have been VERY satisfied.
I bought the CF and then installed an in line immersion heater just before the CF heating the oil up to approx. 150F and then filter at about 5-8 GPH. Once this is done I mix 50/50 with diesel and pour into my 1000 gallon skid tank. At the pump I installed a 2 mic filter as an added bit of protection. I am at approx. 800 gallons on the 2 mic filter at the pump and it shows no signs of restricted flow yet.
The only change that I plan to make is to install a water trap before the immersion heater as I have recieved a lot of oil in 55 gal. drums. A few of these had more than a couple of gallons of water in them,my thinking is a clear water trap/filter would simplify the process.
With my buisness I use 100 gallons of fuel per week approx. so I am always on the lookout for WMO.
I have been doing this for 1 year with ZERO problems.Now @ 40k on 1 truck and about 20-25k on the 2nd. At 35k on 1st truck I had Ryan Casserly remove the injectors and inspect them for any problems. There were no related issues at all only a couple of bad O-rings that were replaced.
For icing on the cake if you go this route, live tuning by Bill @ PHP really was money well spent.
1999.5 F-350 SRW 6 speed,DP tuner,38r/1.15, gulfcoast oil bypass filter, 3.5" turbo back exhaust, MSD propane system, snow water injection, fass fuel system, AFE air filter,372,000 miles and going strong with over 200,000 miles of propane use
cantrellc123 is offline
Old 12-12-2009, 12:51 PM   #9 (permalink)
[quote=airfooter;1801852]What happened to the posse on this forum who used to preach the ways of WMO and blending WVO?? Likely they found out why its not such a good idea... It usually takes awhile because 'it runs great' - right up to the point that it don't run so great anymore - then its often tooooo late.
Welcome back Airfooter....
Dont recall anyone espousing the benefits of blending that you are referring to. I am still waiting for what you keep telling em will happen. 45k later and by your estimations Ive been lucky so far.
Im glad what you are doing is working for you... the WMO crowd is still doing whats working for them as well. Keep us up to date.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
Old 12-13-2009, 03:08 AM   #10 (permalink)
I mostly use atf at 50/50. My wmo is mostly atf but I'll dump in oil and hydraulic oil as i get it too. I then fitler the 50/50 mix. The truck is a 44 gallon tank. I ussually have about 22gals of diesel then I pump in the 50/50 filtered mix.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline
