Cooking oil is bio fuel? - Diesel Forum - TheDieselStop.com
Old 08-30-2005, 03:01 PM   #1 (permalink)
is it possible to use used Conola Oil as part of my fuel mixture? We use about a gal of cooking oil (Canola) around the house in a week. I have to take it to PEP Boys to get rid of it. If i strain it to get the big chunks out can i put it in the fuel tank a quart or so at a time?
Will there be any ill effects?
Rado
2000 250. 140000 miles. Chip, air bags in rear. We pull an 8000lbs 5th wheel.
Rado Kovac is offline
Old 08-30-2005, 03:32 PM   #2 (permalink)
Supporting Member
brett_kartracer's Avatar
Re: Cooking oil is bio fuel? *DELETED*
Post deleted by brett_kartracer. *He was in the wrong forum until the moderator moved it*
-Brett
2001 F-250 Powerstroke, Automatic. Zoodad mod, Airaid filter, muffler delete, Boost fooler, Edge Evolution, Turbonetics 0.84 turbo. Best 14.88@88MPH, 314hp@617trq.
1989 F-250 7.3 IDI N/A, 5 speed, no muffler. Injector Pump turned up 145*.
brett_kartracer is offline
Old 08-30-2005, 04:55 PM   #3 (permalink)
Spencnaz's Avatar
My Photos: (14)
UHHHHH....
he is in the Biodiesel forum.
In answer to the first guy's question:
Yes you can mix that oil 50/50 with diesel fuel, just make sure you dont do this when it's cold out, the veggie oil will gel up and plug the fuel system.
Or.....
You can learn how to make biodiesel and not worry about mixing it with diesel. Sounds like you have a ready supply of WVO for making biodiesel.
Email me if you have more questions.
I recommend www.biodieselcommunity.org
Spencnaz is offline
