Are you using 100% wmo? I would think at least 40% diesel and 10% kerosene would be a much better way to thin the WMO. I currently am at 50/50 WMO/diesel 300 to 400 miles south of your local. If the temps start to stay below 40 degrees for several days then My plan is to drop to 30% WMO as there is a difference in how the truck runs when that cold.
1999.5 F-350 SRW 6 speed,DP tuner,38r/1.15, gulfcoast oil bypass filter, 3.5" turbo back exhaust, MSD propane system, snow water injection, fass fuel system, AFE air filter,432,000 miles and going strong with over 200,000 miles of propane use
I was up to running 66% WMO (remainder diesel) in the summer, but I backed it down to 50/50 for the colder weather. I just figured if I had to go much lighter than that on the oil, it's not really worth the hassle to bring diesel home in cans and add it to my mixing/filtering rig. The gasoline would thin the oil much more efficiently, and probably make it burn a bit hotter which would be nice in the cold weather. I just wondered if anyone had done it before. I'm not sure I want to be the experimenter.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
I mentioned this to a guy who works with me who drives a 78 Mercedes diesel. I have not read the owners manual for that car but he said Mercedes does recomend using gasoline in cold weather. Once we are back to work I will get the owners manual from him and post that info.
I am at 25% oil now in florida. When I have stale gas I just put it in. I have never put more then 1 gallon in when doing 50/50 though. it helps thin it quite well.
2000 PSD XLT CC, AT, 4x4, DP-Tuner, straight exhaust. Sonnax/Tricumulator, 6.0 tranny cooler. Cyberdyne tranny guage. Straight #2 and every now and then a bit of tranny fluid.
So if you cut the WMO enough you dont have cold start issues? Cuz I have 0 degree mornings to contend with right now
03 F-350 DRW Lariat 7.3,4x4 6-Speed, 4.10Gears , 4 inch ProComp lift, BFG AT LT315/75R16, 3 in. spacer between duals.
GT38R 1.0 Housing
Banks Monster Exhaust, w/Turbo Elbow, AFE Stage 2 Cold Air Kit, South Bend Stage 2 Clutch and Cyro'ed Flywheel
DP 80econ -Stuck there for now because someone stole my SCT box
2 Optima Red Tops
Auto Meter Boost and Pyro Gauges
8,200lbs---Cat Scale---Thats me and and 38 Gallons of Diesel
1987 Mustang GT Cobra Clone- crate motor, cage and more suspension than I know what to do with
Loves to run down Vettes and Vipers on the road course
1978 mercedes diesel owners manual.
At very low temps the fluidity of #2 diesel may become insufficient due to parafin seperation. If winter diesel is used, there will hardly be any malfunctions at outside temps reaching as low as +3 F(-16C).
Varying with the temp, add a certain quanity of kerosene,if only #2 summer diesel fuels or less cold resistant winter diesel fuels are available or if temps drop below +3 F(-16 C)
If regular gasoline does have to be added, its proportion should not exceed 30%. Premium fuels are not to be used.
Even at ambient temps of less than-8F(-22C) the proportion of supplementary fuel (kerosene) must not exceed 50%.
The adding of supplementary fuel to #1 diesel is not recommended even at low ambient temps.
+32 to +14 F ----------------50%---------------------------30%
+14 to +5 F -----------------50% --------------------------50%
Have done the same. Have never gone above 10% though. And usually its just a gallon i have used.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
