from diesel to bio - Diesel Forum - TheDieselStop.com
Old 11-11-2005, 09:24 PM   #1 (permalink)
My Photos: (14)
from diesel to bio
How hard is it to take your truck to bio and then back again? I heard it was just the filter change but was not sure
2001 Ford F-350 crewcab long bed srw black gauges boost and pyro 125 hp chip adjustable 10k-3.9k mod. Straight piped 4 in lift with 35`s X-
Terrain. Aceton emblems <font color="red"> Everyone dies but not everone lives </font>
http://photos.thedieselstop.com/show...=39254&thumb=1
coolua is offline
Old 11-11-2005, 09:56 PM   #2 (permalink)
Re: from diesel to bio
Real biodiesel is completly &amp; totally interchangable w/ petroleum diesel in your 2001 vehicle. You do not need to do any thing, and they may be mixed in any percentage. If you're running B-20, it may be quite awhile before you need to change your fuel filter. If you start out using B-100, you'll need that filter sooner, rather than later.
The thing about bio as we head into winter is that is clouds at about 40 &amp; gels about 30. A good blend for me where it rarely gets below 30 is B-50 (half bio half #2). If it gets colder in your area, use B-20 w/#1.
Now, Waste or Straight Veggie oil is NOT biodiesel, and can need some modifications.
OMCUSNR is offline
Old 11-11-2005, 09:59 PM   #3 (permalink)
It's a matter of running your tank empty and filling it up with diesel fuel. For simplicity it's no different running Biodiesel then it is running Petro Diesel.
2005 Excursion Limited; build date 09/04. MBRP T-304 Turbo Back Exhaust. Sickening monthly payment.
rcdallas is offline
Old 11-11-2005, 10:49 PM   #4 (permalink)
My Photos: (14)
ok I thought it was just bio and wvo what the grades of b100 and b10 how many grades are there out there. I want to start making some but now I dont know what ill be making
coolua is offline
Old 11-11-2005, 11:04 PM   #5 (permalink)
Biodiesel is just that: Biodiesel. If you buy it from a vendor (biodiesel station) they will sell some mixture of biodiesel and regular diesel. Our local station only carries B20...20 percent biodiesel and 80 percent regular diesel.
If you make your own, you can mix anyway you want to. In the summer I run only biodiesel so I'm at B100. I've now started to add some regular diesel and am currently running about 75% biodiesel. As it gets colder I'll probably use half and half. So the Bxx number depends on the amount of biod mixed with dino diesel. [img]/ubbthreads/images/graemlins/confused.gif[/img] Does this help any?
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
dssamp is offline
Old 11-11-2005, 11:59 PM   #6 (permalink)
Spencnaz's Avatar
My Photos: (14)
I use biodiesel and petrodiesel interchangebly. With the colder months upon us here in the Northwest, I've been blending some B80 for better cold weather starts and using B100 during spring and summer.
I also have put about 10% diesel into my storage tank so I can add some antigel to the fuel. Antigels will not work with biodiesel unless you add it with some diesel fuel.
Since I'm making biodiesel myself for about 98 cents a gallon, I can afford to buy some petrodiesel now and then.
Spencnaz is offline
Old 11-12-2005, 10:52 AM   #7 (permalink)
My Photos: (14)
Ok yes that helps alot the b## just the % of bio vs diesel that helps a ton
coolua is offline
