Diesel Secret? - Diesel Forum - TheDieselStop.com
Old 05-01-2008, 12:00 AM   #1 (permalink)
Diesel Secret?
Has anyone used dieselsecret.com's product? I know of someone who has and likes it. I am very skeptical about it, but I wanted to see if anyone else has used it.
flamed69 is offline
Old 05-01-2008, 12:07 AM   #2 (permalink)
The search function is your friend.
2003 F-250 7.3
4x2 Crew Cab SB
Garrett Ball Bearing Turbo
40HP injectors
D-P Tuner F5 chip
Ford AIS, with foam shroud and side intake
4" MBRP T-409 Exhaust Turbo back
Vegetable Oil Conversion
1997 F-250 7.3
4x2 Super Cab
D-P Tuner "econo tune" PCM
over 340k miles and countin'
PreservedSwine is offline
Old 05-01-2008, 03:50 AM   #3 (permalink)
Excavator's Avatar
My Photos: (11)
This is better known as DIESEL BLENDING and people have been doing it for years. You face 2 hurdles and the first one is you need a good steady supply of WVO and number 2 is the filtering instructions leaves out the part that you MUST prefilter the oil and it also needs to settle for a few days. By prefilter I mean you cant just run it through the 15 micron filter as they have you beleive or it will clog it up in minutes unless the oil is heated. Just be prepared to have some time to experiment with prefiltering before you think you can just turn on pump and run it in truck. Many have used the bluejean meathod of closing the pant legs and filling with the oil and let it filter over night in to a drum. That works or you can buy long filter bags. Just search internet for filter bags.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
Old 05-01-2008, 08:51 AM   #4 (permalink)
DIESELDUTTON's Avatar
I have been running it for about 1 1\2 months and is working great, but like Jim said make sure you let the oil settle and pre filter it before you run it thru the house hold filters. If you dont, your filters will clog in a matter of minutes. I do have a electric fuel pump and two very good filters on my truck (Dahl 150 and CAT 2 micron) maybe thats why I have not had any issues. Alot will say this method of blending will destroy your engine, I'm at 187K I know I know its just getting broken in , but if my engine fails I will rebuild it or by another and yes I will post if I have a problem. I refuse to let my truck sit and on the other had I cant afford $4.37 a gallon so I figured I would give DSE a shot and so far so good, time will tell. Good luck
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 05-02-2008, 09:46 AM   #5 (permalink)
Angry
I just bought the DSE system and as far as i am concerned it is a bunch of crap. I ran about 60 gallons through my truck and now every filter got clogged and my injectors are very dirty. I took the fuel pump out of the tank and took a peek inside and the hole tank was covered in a white grease. Im gonna try to modify my mixture and hopefully it works this time around.
1997 F350 Powerstroke,reg cab, 4x4, 142,000 miles
JohnMx854 is offline
Old 05-02-2008, 10:02 AM   #6 (permalink)
If this was on your 97 in your sig they dont have a pump in the tank unless you installed a pump in both tanks. Do you have another truck, post 99 that has a single tank, now that I think about it they have a frame mounted pump Good luck with that
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
Old 05-02-2008, 01:38 PM   #7 (permalink)
Thanks for the reply's. Keep them coming. I am still unsure of which route I want to go.
flamed69 is offline
Old 05-02-2008, 06:14 PM   #8 (permalink)
redneck_rheino's Avatar
My Photos: (36)
I too was scamed into buying the DSE, but i started doing research on it and decided to go with biodiesel instead. So far i'm into it about $350 in processing equipment and about 150 gal of WVO saved up. All I have left is to build the wash dry tank and Im ready to brew. Go with Biodiesel, the start up cost will make up for the $4.50 gal #2 in no time and you be using a fuel that is equally as good. However I am glad I bought the DSE cause it lead me to making biodiesel. Its still sitting on melf shelf, The bottle of snake oil, the crushed up poorly shipped box it came in and the Manual which is equally as crushed and torn from shipping. The manual is a joke BTW.
*SOLD* 2005 F-350 XLT Supercab SWB PSD, Zoodad mod, Installed factory clearance lights and tailgate running light, line-x bed liner, sirius radio, GOS racing headlamp harness, Coolant Filter, Toyo M/T's 285 75r 18, platnum injection diesel catalyst system, 4 in straight exhaust, Blue FPR spring and 6.4 banjo bolts upgrade, delo 5w40 syn with hss, 2 stroke oil in the tank
Truck Pics
*SOLD* 2006 Ford Fusion SEL 3.0 V6 dark blue pearl
2011 Ford F-150 Supercrew XLT 4X4 6.5ft bed 3.5L ECOBOOST
2006 Chrysler Pacifica Touring AWD 3.5L V-6
redneck_rheino is offline
Old 05-04-2008, 05:27 PM   #9 (permalink)
...Excuse me if I laugh my azz off over here! You were scammed, huh? I suppose you were forced into buying the DSE Manual?? BTW, if you dont plan on using the 'Snake oil', you could send it my way if you dont mind...
DSE: Great info for me!! Ive saved THOUSANDS $ in the 2 years Ive been making my own 'cold blend'! Im lovin it!!
I do have to admit, I really really enjoy the great humor I get from these threads...
06 F350 KING RANCH,4X4 Dually, Copper/Arizona Biege,loaded with all options including dual alternators & King Ranch chrome pkg, except moonroof..modes DONE: 3:73's replace 4:30's(yes, thats correct),Gear Vendors auxiliary overdrive, MBRP Dual Exhaust, SCT Xcal 2/Innovative Diesel Custom Tune Xtreme Race with full converter lockup,MSD Digital Propane Injection, 03 Turbo & pedestal,custom Intake, AFE Proguard 7. Running "Cold Blended" Veggie fuel(DSE) now for 2.5 years!! Recent(Jun/2008) Fuel System upgrade: FASS Hi-Perf. 0-130psi fully adj. VEG oil specific lift pump & a Racor 'NAUTILUS' Dual Heat primary Fuel/Water filter assy, & a 5/8" "Draw Straw"(Fuel tank pickup tube) with 101000+ troublefree miles and counting!
Traded:2004 F350, 4X4, Super Cab,Sport pkg,True blue (I'll miss her,she was fast!)
BIGBLUE777 is offline
Old 05-04-2008, 05:31 PM   #10 (permalink)
..Good observation I must say. You beat me to it! There seems to be alot of suspicion floating around here!
Old 05-04-2008, 05:40 PM   #11 (permalink)
EXTREMELY COMICAL!! Sorry, I had to say it. Sounds like the oil U mixed was either hydronated and/or loaded with water... Your blend shouldve been a dark 'caramel' color when finished. When I looked in my fuel tank when I did the vent mod after 40,000+ miles of 'DSE mixing'. the inside of the fuel tank was IMMACULATE!! Seriously, it was SPOTLESS
Im tellin U right now, DSE cold blending ABSOLUTELY works!!
Old 05-04-2008, 05:44 PM   #12 (permalink)
Excavator's Avatar
My Photos: (11)
DSE yes it works if you don't rush the process.
If you ask 50 people what they think of DSE you will get bad and good results. The ones with good oil and let it settle and filter the right way they have good positive results. The ones with the bad oil and dont let it settle and rush things have horror stories.
If a doctor tells you you are sick and will die I bet you will go to another doctor before accepting that. There are just to many things that can go wrong if you dont take time and prepare for what you want.
The first few mixes I did was experimental and a learning process.
Now I am just refining my setup but have had good results with DSE.
The manual is a great starting point and you can improve many things as you learn from your mistakes.
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 05-04-2008, 06:09 PM   #13 (permalink)
Absolutely Jim, I had some 'growing pains' when I started the DSE method 2 years ago. I still basically stick with the same method, but use 10% more Diesel for the thinning than what the Manual suggests. I also dont use their additive anymore for almost a year now, as I find the 'white' bottle of Power Service's anti gelling & water displacement additive works equally well!
For me, concerning 'sitting' the oil, I guess so, to some degree, as I recieve my used VO in the cubies they come in & transfer them into a 55 gallon drum for storage. I then just draw out 5 gallons at a time from this drum & mix whatever amount Im going to make in my plastic 32 gallon trash can! Also, I can personally attest it takes me 25 to 30 minutes from drum to my fuel tank, manufacturing a cold blend VO mix!! This seriously pisses off many a 'bio diesel maker' as many cant fathom the reality it does NOT take 5 to 7 days to make alternative fuel!
IMO, the DSE Manual is ABSOLUTELY worth the $39.99 I paid for it, cause it opened the "information door" to Cold VO blending for me.
Like I said in the beginning, I had growing pains, BUT I CHOSE TO STICK WITH THE METHOD & made subtle refinements & after THOUSANDS of cold blend mixes in the 2 years Ive been using the DSE method, I could honestly make this fuel BLINDFOLDED!!
Yes, I say thousands, cause I drive roughly 600 to 1000 miles A WEEK as I am a mobile marine mechanic in South Fla....
I have never blown a high pressure pump, injector or an engine for that matter in either my 04 F350 6.0l or my current 06 F350 6.0l. I ASSURE EVERYONE, ID BE THE FIRST TO POST A HPP,INJ. OR ENGINE FAILURE IF IT WAS DUE TO DSE BLENDING!!
Lenny
Old 05-04-2008, 08:27 PM   #14 (permalink)
firemediceric's Avatar
Lenny
Lenny, if your work ever takes you up to Vero Beach, shoot me an e-mail. We'll have a beer and trade notes on blending.
I, too, got started with DSE. I have made a lot of refinements, but two years later all is still good.
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
Excursion: All stock, so far.
firemediceric is offline
Old 05-04-2008, 09:05 PM   #15 (permalink)
Yea, why not?, though 90% of my customers are south of me, in Ft. Lauderdale area.
I didnt realize you did the DSE blending..or is that a variation of?
Sometimes I get annoyed along with humor, when people spout out opinions negating something they never actually personally experienced for themselves. Also, there is a bit of speculation & suspicion floating about in these forums!
Lenny
