DIY plug-in diesel-electric hybrid F250 - Diesel Forum - TheDieselStop.com
Old 10-27-2009, 05:59 PM   #1 (permalink)
Send a message via AIM to jray3
Cool DIY plug-in diesel-electric hybrid F250
I'm penciling on a diesel-electric retrofit for my 1987 F250.
Goals: Fun, increased torque and acceleration, ability to get max mpg, and bragging rights.
Qualifications: already built my own hi-po electric car.
Basic project specs: 6.9 IDI, 2wd with a t-19 4x4 tranny with the 6.32 granny and 1.00 fourth gear, 3,55 rear end.
Hybridization by adding a 6.7" dc electric motor of up to 156 volts through either the PTO or the transfer case. Both options would allow for electric-only drive, and also to disconnect the electric motor for long highway trips. PTO drive would allow me to continue the project by adding 4wd. However, transfer-case drive allows multiple gear ranges, is probably capable of more torque than the PTO, and has some ability to engage and shift on the fly, while the PTO must be engaged only at a dead stop. Anybody know of a downside to letting the PTO be driven, rather than be the driver, and maximum pto torque and rpm possibilities?
I can put in a lot of electric power; am considering setups of 25 to 120 peak hp, all possible using the same motor, which would only put out about 20 hp continuous, though the motor would rarely be used for more than a minute or two at a time... Max torque output of about 60 lbs.
Any comments or suggestions are welcome.
jray3 is offline
Old 11-25-2009, 06:15 PM   #2 (permalink)
There are some PTOs that are clutch pack driven, you would need an air system for it though. There are HP limits to PTOs, I think the transfer box is your best bet though. Please post more as you build.
dbwright is offline
Old 11-30-2009, 09:04 PM   #3 (permalink)
Pushing thru the transfer case...
Thanks DB. Next problem seems to be that the gearing is wrong for adding power thru a transfer case. For a direct current electric motor, I want about twice the engine rpms, not half (in lo). Adding another gearbox in series would add losses.
Any chance the BW 1345 gearing can be reversed, to reduce engine rpm rather than increase it at a given speed?
My other option would be to add a motor to the engine compartment with a belt drive. I could possibly fit a motor in place of the air conditioning compressor, would just need a stouter belt. Have considered swapping out the v-belts for a 7.3 serpentine setup anyway. Any ideas on how much torque that ribbed belt can handle, or if options exist to swap it for a cogged belt?
Cheers,
Jay
jray3 is offline
