The DFA/Vegistroke is not for IDI's and the greasecar kit is junk resembling middle-school science project (so are the other 'contenders'). That leaves Frybrid, who just happen to build the highest quality system available. I have seen 2 IDI vans running Frybrid kits and both had 1000's of trouble-free miles.
What you want:
- (2) tank system that only heats the VO to be burned, NOT the whole tank (Frybrid-exclusive in-tank HE cannot be beat, extremely effective)
- NEVER heat the diesel
- a system that is as close to OE quality and fit as possible (this helps ALOT w/the servicing concern - trust me, I have met dozens of greasecar kit owners, several who have flat out been told 'NO way, we're not working on that')
- a seperate fuel pump and filter for each fuel
- never switch over until VO is up to temp (180*F or higher)
- controlled loop return - this 'recycles' the heated fuel back to IP, rather than returning to tank
- minimum 3/8" aluminum TIH (tube in hose, aka HIH, hose-in-hose) PEX does not make reliable fuel line. another Frybrid exclusive - NEW STYLE HIH ends make VO/coolant contamination almost impossible
- heated fuel filter (the coolant-heated Frybrid unit is VERY effective, but 2-300 watt elect blankets may be ok)
- at least a 16 plate FPHE (flat plate heat exchanger) just before IP
- NO cross-contamination, VO should NEVER go into diesel tank (6 way valve GARUNTEES VO in diesel tank)
- minimum purge time that ensures no VO is left in IP or injectors
- should 'switch over' in under 10 miles and purge in under 1 minute
I travel all over the country for work and have met dozens of VO people and seen a bunch of conversions. Across the board, everybody that had any miles on anything other than Frybrid or REALLY nice DIY had lots of issues. I have not met a single GC kit owner who has not replaced IP. I have met at least 3 who threw GC kit away and replaced w/Frybrid.
Here's the facts. If you drive much, you WILL get your money back. If you spend the money up-front and buy a high quality SYSTEM, you will likely get your money back FASTER. Why? It will work the first time, and every time. The hidden secret is those who claim success often can only use liquid (non-hydrogenated) VO and still struggle in the cold. Many have ridiculous purge times and still fail to clear the IP and engine of VO and return VO to the diesel tank. VO will often seperate from diesel and line the bottom of tank w/sludgy, cold VO. Since the diesel pick-up is in the lowest part of the tank - when you start engine cold, it is slurping up cold, thick VO and injecting (as best it can) it into a cold combustion chamber. Unless you are really, really new to this - you already know cold VO is BAAAAD.
I like to tell people to choose wisely, or at least post pictures of the carnage!
good, informative, fact-filled (with back-ups and reasearch) info at frybrid.com
Choose wisely. Or
PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
