E85 for blending ?? - Diesel Forum - TheDieselStop.com
Old 07-15-2009, 02:17 PM   #1 (permalink)
E85 for blending ??
I have been blending my fuel now for about 6 months with very good results. I mix fuel and setteled WVO in a 15 gallon poly drum then vacuum filter it down to 1 micron. I use a 50/50
WVO-diesel mix or a 75/25 WVO-RUG mix.
Question,
E85 is a bit cheaper than RUG or diesel. It is also a lot thinner. Has anyone blended with E85 and at what %
Thanks all
Build date 9/98 F-250 SD 172" 4X4 7.3PSD 6 speed
188,000 miles, all stock
TIMLUTZ is offline
Old 07-17-2009, 07:22 AM   #2 (permalink)
skunk's Avatar
e85 kills small engines. i use the rug if it were me.
Northern Woodland & Tree Care work trucks:
old smokey
- 86 Ford F250 6.9 IH navistar non-turbo idi diesel 4x4 dana 60 rear w/ limited slip, dana 44 front wishbone style, w/ 3.55 gears, C-6 w/ oil coolers, manual walbro frb-13 fuel pump, manual wellman glow plugs, K&N air filter no soup bowl and a homemade cold air intake, 3 inch pipe, class 31 heavy duty tractor truck batterys, lots of real gauges.
big drippy - 86 Ford F350 4 door crew cab, long box, 7.3 Navistar IDI non-turbo diesel, 2wd Dana 70 dually rear with 4.88, c-6 w/coolers.
The Swan - 87 chipmore wood chipper chuck and duck old school style. vm motori sun 4505 3.9 air cooled non-turbo DI 4 cyl diesel, rockford pto.
skunk is offline
Old 08-20-2009, 10:28 AM   #3 (permalink)
Originally Posted by TIMLUTZ View Post
Question,
I was wondering this same thing. K1 is way too expensive ($6/gal) here in NM and E85 should be as good a thinner as K1. From what I’ve read, alcohol and diesels go together very well. They have converted diesel engines to run on just E85 also. On my 99 PSD I blend in %8 RUG (two tank system – HOH with electrically heated manifold). 97 MB blend 10 gal WVO, 1 gal Rug, 4 gal diesel and sometimes 4oz shot of turp. I’m thinking of trying 10 gal WVO and 3 gal of E85 in the MB.
red5jedi is offline
