Emergency situation... 100% veggie oil? - Diesel Forum - TheDieselStop.com
Old 01-25-2006, 01:25 AM   #1 (permalink)
A few times I have come VERY close to running out of fuel in remote areas. IF you are in distress without a diesel fuel stop is it possible to run an unmodified truck without damage on a few gallons of veggie oil?
01 PSD F250 Lariat CC 4X4, Autometer Phantoms, BD Intake, 203* Thermostat, AFE Filter, Tru-Cool Tranny Cooler, TS Performance 4 bank chip, MBRP Exhaust, Pioneer Premier XM Headunit running Sirius, JL Audio, Infinity. Ranch Hand Bullnose.
Markstanco is offline
Old 01-25-2006, 05:48 AM   #2 (permalink)
Re: Emergency situation... 100% veggie oil?
Mark
I'll give you a real clear maybe. [img]/ubbthreads/images/graemlins/grin.gif[/img]
It would depend on the temp if its hot say 90F sure a few gallons proabbaly would not hurt anything. After all they say a diesel will burn anything but for how long is the question.
This depends on the vehicle also. I like the PSDs setup with the fuel lines running through heads. It makes for a nice hot area for the fuel to get up to temp, veggie or diesel.
Hitting the local conviniance store for a few bottles of veggie when you run out of fuel may just be the ticket. Who needs AAA.
B & E
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000, and Vegtherm
Converted at 3900 miles now have 32945
BandE is offline
Old 01-28-2006, 12:27 AM   #3 (permalink)
I will second B_E. I diesel will burn nearly anything you can get in the cylinder for a short time. A few gallons of virgin oil from a super market will likely hurt nothing but the wallet.
Go SEAHAWKS!!
fordnut74 is offline
Old 01-30-2006, 12:21 PM   #4 (permalink)
The problems you would face would be injector coking and I think HPOP damage from running a "fuel" that is too viscous. Veg oil should be 160 deg. before running through the system. I don't think a gallon or two would do you in, but who can say for sure? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
<b> Back in Black
1999.5 F-250 SCSB Lariat, 6spd, 145k, Stock for Now (Gimme a Break... I just got it!)
ahawks9er is offline
Old 01-31-2006, 12:10 PM   #5 (permalink)
My Photos: (12)
If you are in a remote area, what are you doing carrying a few extra gallons of veggie oil? Why not just carry a few gallons of diesel?
-Rhino
2001 Ford F250 Platinum Edition. Airaid intake, and the Juice/Attitude combo, Magnaflow 4" stainless dual system, Harley Edition front grille/bumper 14.5 inch Donahoe lift, crossover steering, fox 2.0s, rolling on 22.5 Alcoa floats!
2003 Excursion XLT 4X4
2001 Monster F350 XLT CrewCab 4X4 7.3 PowerStroke, Bright Amber Metallic 12" lift, Dual 2.5 King shocks. Prerunner light bar with 4 PIAA Pro Racing 80XT lights. 39.5" Super Swampers on 16.5X12 Weld Typhoons. Drivelines by High Angle Drivline. Gone but not forgotten!
HugeF3fity is offline
Old 01-31-2006, 02:59 PM   #6 (permalink)
Halitosis's Avatar
I think that he is planning on using a couple of gallons of spare veggie oil AFTER his couple of spare gallons of diesel fuel are gone. [img]/ubbthreads/images/graemlins/grin.gif[/img]
'02 Ford Excursion Limited
7.3L PSD -- 170,000 Miles
Hellwig Sway Bar
Firestone Ride-Rite Air-Helper Springs
203* Thermostat
Teconsha Prodigy Brake Controller
Sirius Satellite Radio
1995 BMW (Euro-spec!) M3
1974 Human Wife
2002 Human Son
"7/5 children suffer from ADHD... won't you help?"
(Running Vegistroke WVO system (HIH)--> 75,000 MILES AND COUNTING!)
Halitosis is offline
Old 02-04-2006, 04:49 AM   #7 (permalink)
I agree with the above posts...I did some "testing" using strainght filtered underheated crankcase oil in a Lister clone. Back when I only half understood what the parameters are. Engine ran ok but was super hard to start if left cold, but I typically switched over from diesel to oil after warm. Got lots of coking, and worse, blowby that would raise the oil level in a few hours of run time that would overflow the crank case. A disassembly showed the cylinders were fine, but the heead gout seriously coked up, the valves needed scraped, the injectors fouled and coked. All no problem on a Lister, and the parts are cheap so it was a great experiment. Didn't have to replace anything though, the engines are tough. I will never run crankcase oil again in an engine though, but when I get it set up again (down for cooling and generator mods) I sure will run lots of heated veggie through it [img]/ubbthreads/images/graemlins/smile.gif[/img] Just food for thought. Long term use will certainly cause coking problems but a few times here or there shouldn't be an issue. I am finding i have to watch, cause it's tempting to switch over to veggie in my truck before the engine is quite warm, since I run so many short trips, but removing injectors to clean them would be a big job, so I'll wait till warm, even though it kills me!
2004 F250 Super Duty 4X4 6.0L Crew Fx4
flyingisbest is offline
