anyone done it? I am thinking of trying it with a worhtlss chain saw. Any recomendations on mixture quantities? I figure I will start out heavy on the biodiesel that way I dont ruin any internal parts with friction.
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
It won't work. You need high compression for the biodiesel to ignite. Need a sparkplug for the alcohol to ignite and a glow plug for the biodiesel. How are you going to coordinate the two events ?Your arm is going to fall off just cranking the combination.
Wolf
Kentucky built 2004 Silver F-250 XL Reg Cab PSD, 4X2, bench cloth seat,air conditioning, 6 spd Manual, 3.73 LS,Line-X , FORD receiver, Prodigy brake controller,towing option,( put together on Monday, March 29, del April 9 2004) 62000 miles
2 strokes you mix the gasoline and the oil. the gas/oil lubricates the internals of the engine since there is no 'oil stroke'. In this case gasoline = ethonal, biodiesel = oil.
With biodiesels extraordinary lubrication properties I am thinking that it may be good enough to lube a 2-stroke.
I am not worried about or trying to ignite the biodiesel through compression, that would never happen in a low compression motor.
What i am worried about is having enough lubrication while still being able to ignite the ethonal.
1993 Ford IDI 7.3L
F-250
Class 5 hitch
super cab
18x,xxx miles.
Purchased 9-22-06
Why not just run svo? Unless you have biodiesel around. I know you can run a 2 stroke 0n ethanol. You just need to richen your mixture up. I would just run a rich mixture of fuel to oil. Like 24 to 1 like when you use to use 30 wt motor oil as 2 stroke oil.
Sold, 97 F250 Supercab back to the 85 S10 and loving it.
I misunderstood the original post. I thought he wanted to burn biodiesel instead of gas. Sorta like having a diesel chain saw.
Wolf
well alright then, I am going to go for it. We have an e-85 pump and I just signed up for the biodiesel coop. I will keep you updated on how it works out.
firstrattler, I thought you misunderstood, but i thought i would explain anyways [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1993 Ford IDI 7.3L
F-250
Class 5 hitch
super cab
18x,xxx miles.
Purchased 9-22-06
Go for it. Keep records. My friend in college wanted to put a HODAKA motorcycle transmission on a chain saw. Now that I think about it, having a five speed chainsaw would be cool [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Wolf
Just keep an eye on bearings and piston ring wear.
The Green Monster: 2001 F250 Powerstroke, 2WD, ZF6 transmission. Going to tune for maximum fuel economy. Will be running B100 soon, stay tuned.
The POWERSMOKE is dead !
1986 F250 4x4 XLT Lariat Explorer, 6.9 with Hypermax Turbo and cowl induction.
221k miles , C6 Transmission. Gear Vendors. Dual tanks with 50 gallon tank added to bed, locking canopy. Dana 50 TTB with Ford 10.25 rear and 3.55:1 ratios. Running B100 with no ill effects. Homebrew BioD. 80 gallon biodiesel processor with custom machined vacuum venturi
I heard about using biodiesel in place of two cycle oil back in December and did some checking over the internet. Most people say that it doesn't work too good. I was interested in because I run a lawn care service and thought it would be a good way to lessen pollution. I think going to one of the soy based two cycle oils is the way that I will go. You can find info on those here.
As far as using E85, it might be hard on the plastic and rubber parts. I think E10 is probably safe for most things, maybe not really old equipment, but E85 may be pushing it.
If you want to "go green" with your chainsaw just get you some castor oil. It's hands down the best oil for a 2 stroke. Any ammount of diesel, biodiesel or WVO in the gas is going to suppress combustion and give you a lot of smoke.
Build date 9/98 F-250 SD 172" 4X4 7.3PSD 6 speed
188,000 miles, all stock
