Excessive smoke with wmo - Diesel Forum - TheDieselStop.com
Old 09-18-2008, 11:51 PM   #1 (permalink)
My Photos: (14)
Send a message via AIM to edub32
I'm running about a 85% wmo (5 micron) diesel right now and for some reason lately ive been starting to get a lot of blue smoke. at 65 in OD it seems to clear up but at starting and medium speeds theres quite a bit. should i premix before pouring into tank or am i running to "rich" of a mixture.
2001 F350 7.3 SCLB 4x4 Off-Road SRW
- DP Tuner, Tymar intake, 35" BFG Mudders on 16x10 Mickey T's, Superlift 6" lift, DiPricol 3 gauge Pillar, 4" SS DP to 5" sidepipe to 6" Chrome tip, WW, Panasonic Deck with 4xInfinity References, Overboost Elim., CCV
edub32 is offline
Old 09-19-2008, 08:31 AM   #2 (permalink)
Send a message via AIM to rockets10510
i pre mix. it could be that you are running to high of oil mix. try going to a 50% WMO or 25%.
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 09-19-2008, 09:46 AM   #3 (permalink)
My Photos: (14)
what is the highest % you guys use without any smoke?
edub32 is offline
Old 09-19-2008, 09:54 AM   #4 (permalink)
Sounds like you are running too thick a mix. I have run 100% wmo with no more noticeable smoke but the ambient temp was high. Meaning it was hot outside.
I now run in the 80 to 85% range. Is your source actually wmo or some blend of that? Sometimes people get a blend of used oils with different weights and i have noticed a difference there.
I run a heat exchanger so it affects me a little less than most. And I test my mix with a hydrometer so that its near or the same as #2. Bio-Diesel: Farm Grown Profit will help you with that.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
Old 09-19-2008, 03:11 PM   #5 (permalink)
arthurgoboom's Avatar
How do you get WMO to be the same specific gravity as diesel fuel? The WMO is a thicker, heavier oil and I don't see any way around that except for heating or thinning.
edub32, in my IDI, it will smoke alot at idle with a 50% WMO/50% #2 blend. I'm now running 66% oil and I try not to let it idle too long to avoid smoking people out and building up deposits on the pistons/valves/etc. As far as I can tell it doesn't smoke any when running at road speed.
1986 F250 2WD Super Cab XLT Lariat w/ 1996 front clip. Dually bed & van rearend (2" wider, allows spring clearance). 6.9 w/ approx 120,000mi. Banks non-wastegated turbo system, Wellman G088 glowplugs, Delphi BB injectors, Kenworth pyrometer, vac/boost gauge, electric water temp/oil psi/voltmeter mounted in dash. 3" Mandrel-bent open exhaust. C6 trans, 3.54 gears. Okiegringo idler pulley. R134a A/C conversion. WMO/diesel blend in one tank.
arthurgoboom is offline
Old 10-14-2008, 08:44 AM   #6 (permalink)
I run 2thirds diesel 1 third oil in a four cylinder Ford trader and have a slight smoke at wide open throttle [most of the time] as it is loaded all the time.
Tried heavier concentration of oil that smoked and at idle would run a oily deposit out the exhaust[short and no baffles].
Hot motor=better burn.
Regards
Ron
2000 F350 king cab 4x4,No engine mods,Roo Bar,Headlight and bonnet stone protectors,Inlet snorkel,flares on front,Engine driven air compressor and receiver,Hot water tap,tyre temp and pressure monitor,95 ltr fuel tank under right hand side,aluninium side steps,flat trayback,50ltr water tank under left hand side,heavy wired front and back for 4500lb electric winch, Bilnstien shocks,converted to right hand drive,battery conditioner,electric trailer brakes,heavy duty tow bar,synthetic oil in tranny,extra tranny coolerand filter ,tranny temp & pyro,
Ride-Rite airbags all round.Full flow muffler outlet at rear of vehicle.Engine breather mod.HHO generator
knapp is offline
Old 10-14-2008, 11:44 AM   #7 (permalink)
Indeed. Mine is definitely happier now that I covered part of the radiator and the engine maintains 195-200*F. I think part of the equation is the water temp where the coolant comes back into the engine, if that is too cold then part of the cylinders will be too cold. I'm kicking around putting a temperature gauge in the water inlet, and covering/uncovering my radiator to maintain 120-130 inlet temps.
Old 10-14-2008, 08:43 PM   #8 (permalink)
I have a 2000 i have been up to about an 85% to 90% oil and have noticed that with hydraulic fluid there is more smoke at medium speeds and idle than used engine oil. Temps. have also cooled down which play a big factor in the smoke. getting on it hard a few times to clear it all helps out some when getting into cities where i feel bad.
2000 Ford F350 7.3 Ext. Cab Auto.
Armboy9589 is offline
Old 10-15-2008, 09:25 AM   #9 (permalink)
I run 50/50 mix. I mix first then filter down to 2 microns. Mine smokes at idle. The longer it idles the more it smokes. Once moving there is no smoke. Of course if you get on it or pulling hard it will smoke like on regular diesel.
2002 EX 4x2 Amsoil front to back with Amsoil oil bypass filtration, Cyclone Power fan, HX oil line, Dieselsite prepump and tank mods, local high performance transmission, MagHytec pans,MBRP 4" exhaust, AFE Stage II, BD EBV exhaust brake, Bright Box, Diesel Turbo Life Saver, Dieselsite 6pos. chip, Trans, EGT, Pyro and water temp gauges, Dieselsite tranny cooler, Dieselsite 203dg t-stat, Dieselsite AIH plug, rerout ccv, Coolant filter, Firestone Ride Rites, hellwig rear sway bar, Garrett BB turbo. Dieselsite hpop filter, Auto Enginuity program. Dieselsite Adrenaline hpop.
skibarefoot is offline
Old 10-15-2008, 11:28 AM   #10 (permalink)
ReefBlue's Avatar
Am I the only one that doesn't care about smoke?
I run 90% or so, if it is warm out, I run basically 100%. This winter I guess I have to step it down to 50%. I don't care about the smoke.
Should I care??
ReefBlue is offline
Old 10-15-2008, 04:13 PM   #11 (permalink)
What you do is your business. Me personally, I feel self conscious when i'm next to someone in traffic and filling their cabin with the acrid smoke and carcinogens.
The hardcore environmentalists might give you a hard time, call the police/etc.
Old 10-16-2008, 08:06 AM   #12 (permalink)
ReefBlue's Avatar
I have thought about it when I drive off next to a bunch of people standing on the corner or something. I also try not to line up next to people's open wndows if possible, but the usually roll their window up just because of my engine noise anyhow.
My cover story if a cop stops me for smoke is that "I've been having problems recently."
ReefBlue is offline
Old 10-16-2008, 05:49 PM   #13 (permalink)
airfooter's Avatar
The 'smoke' is unburnt fuel and soot. If ya think that its not leaving deposits in your combustion chamber, you are really, really naive.
Beyond that, it stinks and increases dangerous toxins in the air we all have to breathe. Listen, diesel fumes are bad enough in a truck that runs RIGHT - w/no smoke.
I could give a sh!t that you are destroying a perfectly good truck, maybe its not worth much to you - but our kids and grandkids will spend their lifetimes trying to undo what the industrial revolution did to our environment. Why do you think we have 'clean diesels' now? The PSD cut emissions like 90% over the original IDI engines - why go back in time?
Look, I am not a 'tree-hugger', per se - but I recognize the fact our air IS cleaner than it ever was in my lifetime. Luckily, like the dinosaurs and the huge, polluting cars of the 60 & 70's - the 'old geezers' whose belief that the earth is too big and resilient for us to damage are dying off, albeit slowly...
Like I always say, y'all choose wisely or PLEASE, PLEASE post pics of the carnage!!
Choose wisely. Or PLEASE post pics of the carnage!!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, SB Con OFE, AC code injctrs, GTP 38R. Vegistroke-inspired WVO system w/150,000 trouble-free miles! BTS tunes, 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - BTS trans and tunes, AIS, Frybrid/V3 SVO conversion with over 100k VO miles so far!
That's 250k miles on SVO between them!
airfooter is offline
Old 10-16-2008, 09:30 PM   #14 (permalink)
My Photos: (14)
Hmm I love how you post worthless information on everyones wmo and wvo mix threads. I'm asking for help not your criticism. I believe someone posted on here their emissions test with wmo and it ran cleaner then #2.
edub32 is offline
Old 10-17-2008, 05:36 PM   #15 (permalink)
airfooter's Avatar
You are correct, my appologies. The truth is, you are at least a little uncomfortable with your decisions, or ya wouldn't have posted what you did. I know my 'information' is useless to those who have already made up their minds, but my hopes are only to save those for whom it is not too late.
I hear horror stories all the time lately about folks having major engine problems from running 'blends' of WMO and WVO. It seems most folks aren't as 'lucky' as yourself and the others here that tout WMO as a great fuel alternative. (are ya still lucky, my smokey friend?) Of the 1000's who read these threads, how many post? Right.... of the rest, how many 'try it'? So add to that it may take ya 20-30k miles to fubar your engine or take out that 1rst set of injectors (tip of the iceberg, btw) - and you've really had some impact!
Saving the world always has been a thankless job! (gimme a break! like I take myself even a fraction that seriously!)
Thats why I always say choose wisely or post the carnage!
FWIW, I promise not to muddy up another one of yer threads - for awhile... and as always my friend, the beers are all on me, cheers!
