Re: finished amount
Starting with 40 gallons of oil and 8 gallons of methanol/lye I end up with aywhere from 38 to 42 gallons of processed fuel depending exclusively on the quality of the oil. My recipe never changes.
How can you produce more fuel than oil that you started with ? I was under the assumption all the methenol and lye came out as glycerin, leaving only the original amount of oil as usable fuel.
Not all the methanol comes out in the glycerin. After all, biodiesel is otherwise known as methyl esters. That means that some of the methanol reacted with the oil to make methyl esters and some of the methanol reacted with the oil to make glycerin. There were 48 gallons total in his reactor; so 38-42 gallons of fuel is very possible. It all boils down to the oil quality.
OK, wait a min. [img]/ubbthreads/images/graemlins/confused.gif[/img]
My understanding is if you had virgin oil, as in best quality possible, you could theoreticallly get 100% conversion to Biodiesel. We can't really get 100% in used oil, but we get close. So if he started with 40 gallons of oil, and he gets 42 gallons of "fuel", that would be 105% conversion. [img]/ubbthreads/images/graemlins/eek.gif[/img]
I would have to say that there must be 2 gallons of something that is not biodiesel there.
'99.5 F250 crew cab, stock
'02 Excursion stock
Check out my blog: The Fixit Shop
