Finished bio storage - Diesel Forum - TheDieselStop.com
Old 11-21-2005, 01:29 AM   #1 (permalink)
Can I use a tote to store biodiesel for long periods of time?I want to make as much as possible and put it directly into a tank.As I need it just fill up from that tank and try and keep it as full as possible incase of slow times.Maybe have 2 or 3 tanks(2 bio one unproccessed WVO waiting for its turn in the still).Last thing I need is to come out one day and see a biofall comming out the door when the tank fails and 320gallons of golden goodness turns into fertilizer.
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Execution coming soon.
1994 F350 Crew Cab Dually,7.3 IDI turbo-Blowed up. White Lightning
1971 M35A2 deuce and a half. Martyr Machine
1971 M35A2 deuce and a half.Messiah
1957 M52 gasser 5 ton tractor
1968 M543A2 5 ton wrecker sent to china in tiny peices.
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
Beware of Steelsoldiers.Run by Liers and backstabbers.
m35a2 is offline
Old 11-21-2005, 09:59 AM   #2 (permalink)
Re: Finished bio storage
Yes you can BUT "long time" is relative. If it's a few months, yes.
ALL the water has to be gone (should be anyway) to minimize the chance for bacteria to develop. It should not be sitting in the sun nor in a 100F garage (in the summer).
Also consider the high specific weight of B100. Not all totes support that weight! They first bulge then break
MySpace.com/FishHarder
Don't be afraid of death - be afraid of a half lived life!
TurboHans is offline
Old 11-21-2005, 10:34 AM   #3 (permalink)
My Photos: (14)
I have seen a local biodiesel producer use them, though he runs the output though a very large collessing filter before he delivers. I would think the drawback for long term storage would be the extra surface especially when you get low in the tank. Maybe some form of inerting gas would help.
1997 4x4 f250 psd with full Banks Powerpack, turbo, intercooler,large exhaust pipe. Fordnut74 WVO conversion! 203 degree T-stat. BTS-transmission with super duty cooler. 60 gallon aux tank for burning WVO
freds is offline
Old 11-21-2005, 11:27 AM   #4 (permalink)
Spencnaz's Avatar
My Photos: (14)
I'm using a 160 gallon aluminum fuel tank I found at a scrap yard.
This way I can keep it out of sunlight and relatively cool when the tank is outside.
And yes, all the water has to be out of the fuel or bacteria will start to decompose the fuel. Also, water in the biodiesel can form peroxides which can collect on injector tips.
Spencnaz is offline
Old 11-21-2005, 11:18 PM   #5 (permalink)
Freight_Train I found an article with some good info HERE.
Hope this helps!
