First tank of B99 in my 1997 F350 7.3L - Diesel Forum - TheDieselStop.com
Old 08-04-2007, 09:43 PM   #1 (permalink)
Well after some research and encouragement, I've started my new truck on B99 from a local reseller. Runs beautifully and smells much nicer. Thanks for the info you all have contributed.
brycem is offline
Old 08-05-2007, 12:31 AM   #2 (permalink)
hheynow's Avatar
Re: First tank of B99 in my 1997 F350 7.3L
Have an extra fuel filter with you at all times. B99 will bring up the mineral deposits from your tank and clog the filter. After a few filter changes you'll be clean as a whistle. Keep an eye on the two fuel return lines from the FPR to each head. You may have plastic split loom around the hoses. Many including myself have had bioD melt down on those hoses after months of B99 use.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 08-05-2007, 02:22 AM   #3 (permalink)
Roger that fuel filter, but could you break down the process by which I would "keep an eye on the two fuel return lines from the FPR to each head to see if I have a plastic split loom around the hoses"? I'm guessing that stands for "fuel pressure regulator" or some such? This is my first diesel which I've had for all of two weeks and I haven't yet got my Chilton's for it :-) This is going to be an adventure.
**1997 F350 Crew LB DRW 7.3L Biodiesel**
brycem is offline
Old 08-05-2007, 02:40 AM   #4 (permalink)
The two rubber lines that go from the Fuel Pressure regulator to the front of the heads. Mine lasted about 2 years on B100.
If you touch them and they leave a black goo on your finger, change em.
I had a hydraulic shop make some new ones out of Parker Hose low permeation hose, well see how long they last. The replacement custom made ones were only about 25 bucks.
I have over 40k on B100 on my 97.
I changed the o rings in the F.P.R. last year, no problems just had the bowl out to repair fuel heater and did it at that time.
The transfer tank I have (110 gal) has a heated filter on it as well.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 08-05-2007, 06:30 PM   #5 (permalink)
Thanks for the heads up guys - Even with the probability of some fuel system related annoyances down the road, I'd say that rolling down the road on $3.10/galon biodiesel still beats all hell out of $10.00\gallon dinodiesel (http://awakeatthewheel.net/2007/06/0...over-10gallon/)
Cheers,
-Bryce
brycem is offline
Old 08-06-2007, 02:17 AM   #6 (permalink)
Where do you get Bio in Seattle for $3.10???
1997 F250HD, PSD, Supercab XL, ZF 5 speed 4x4, Tymar intake running on B100
vaulter83 is offline
Old 08-06-2007, 11:54 AM   #7 (permalink)
Spencnaz's Avatar
My Photos: (14)
Dr. Dan's in Ballard has biodiesel for about that price. Also the Issaquah Grange has biodiesel 'round that price.
I make my own, but will sometimes buy it from the pump to supplement my supply.
American Hose and Fittings in Kent will have the replacement Parker hose for biodiesel use. I bought 20' of that stuff for $1.20 a foot. Give them a call and they can deliver it to you.
Spencnaz is offline
Old 09-29-2007, 03:35 PM   #8 (permalink)
I get mine at Laurelhurst Oil in U-Village. Don't forget to mix in the winter. I was in Yakima with probably a B75 mixture last winter and the truck barely ran until I through some petro diesel in it.
2001 F250 4x4, SRW, Supercab, stock with Superchips Tuner, Napa Tymar, and B99 all the time
gibbycu is offline
