Fittings! - Diesel Forum - TheDieselStop.com
Old 08-16-2009, 06:33 PM   #1 (permalink)
Fittings!
This is aggravating.
I finally got my new/second tank filter and filter base.
But it didn't come with the nipples!
I've tried auto parts stores and hardware stores without luck.
The threads are 1/2 inch and need to go to a 3/8 inch barb.
Where the heck do you find these things without ordering online?
longwolf is offline
Old 08-16-2009, 06:40 PM   #2 (permalink)
Send a message via AIM to rockets10510
try ace hard ware or home depto. that where i got mine. you could also maybe use the pex fittings. i am useing some of those also.
anthony
1997 F-350 2WD SRW White Crew-Cab Bought in 3-05 w/196,xxx miles 280,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, TW 6 pos chip, stage 1 DIY injectors, fully build racerx trans, B & W turn over, coolant bypass filter, intercooler.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
Fuel Bowl 262,000 NEW from Ford $348.00
rebuilt trans my self with racerX parts. 265,000 $2800.00
DIY Stage ones 267,000 $350.00
Waterpump 265,250 $70 Thedieselstop
Flexplate 280,000 $85.00 autozone
1997 Ford F350 2WD SRW Green Crew cab bought 06-07 with 232,000 miles, Now 238,xxx miles, AFE exhaust, oil bypass, coolant filter, , 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 08-16-2009, 06:46 PM   #3 (permalink)
I've tried a True Value and a Lowes.
Closest I came was one made of plastic, not going there!
I did find a 3/8 thread to 3/8 barb that could be used with a reducer but who wants more chances for leaks.
I'll try an Ace if I can find one.
longwolf is offline
Old 08-16-2009, 11:39 PM   #4 (permalink)
luckuslucas's Avatar
Home Depot usually has a decent selection of brass fittings. If not, McMaster-Carr is the best place to order that kind of thing online.
'01 Dodge Ram 2500, Cummins HO, 4x4, 6 speed, homemade WVO system
'96 International/Bluebird school bus, DT466, homemade WVO system, www.thebiggreenbus.org
'04 Jetta TDI, Greasecar WVO conversion (chases the bus around the country)
'89 MCI 102A3, Detroit 8V92TA, Frybrid/Rover Hybrids custom system
luckuslucas is offline
Old 08-17-2009, 12:48 AM   #5 (permalink)
My Photos: (60)
You do not say where you are from. If you do a google search for (name of your city) +"parker hannifin" you should find the nearest Parker Hannifin store to you. If there is not one close look for a hose and fitting store, a hydraulic shop, an agricultural or heavy equipment dealer nearby. Any should be able to set you up.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 08-17-2009, 04:48 PM   #6 (permalink)
I found a Home Depot and they had what I needed.
Thx for the help folks!
longwolf is offline
