The FOOLPROOF way to make biodiesel? - Diesel Forum - TheDieselStop.com
Old 12-13-2005, 06:03 PM   #1 (permalink)
I found this artical on journey to forever by Aleks Kac have any of you guys tried this method?
Foolproof biodiesel process?
tpendergraft is offline
Old 12-13-2005, 06:34 PM   #2 (permalink)
Re: The FOOLPROOF way to make biodiesel?
oh man, go rinse your brain out. Everythign in that article is garbage.
Acid-catalysed esterification is a good thing, though trickier than regular base-only biodiesel. ANd it depends 100% on doing titrations. It's a way of reducing the titration values of bad oil- totally pointless for good oil (which they recommend in that article) unless you like to handle extra poisons for fun.
But the Aleks Kac monstrosity at the journeytoforever website is complete, utter crap. THere's so much bad information in there it's hard to know where to start. THe reason I said 'rinse out your brain' is that the bad info in that article will actually confuse you about the biodiesel process- it's better to try and forget anythign they said in there.
Here's a forum devoted to the 'real' ways to do acid-catalysed esterification (acid process is a sort of pretreatment you do to clean your oil up a bit prior to making biodiesel):
http://biodiesel.infopop.cc/groupee/...rm/f/629605551
and here's just one of the many discussoni threads that talks about what's wrong with the ALeks Kac formula:
http://biodiesel.infopop.cc/groupee/...51/m/328607547 (you kind of have to understand what the titration is to follow this thread- here's my writeup of titration:
http://www.biodieselcommunity.org/titratingoil/ )
bottom line:
ignore, ignore, ignore that Aleks Kac article
Mark
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
Old 12-13-2005, 07:49 PM   #3 (permalink)
Spencnaz's Avatar
My Photos: (14)
I second that assessment of that article.
I made a small 1L test using their method, it was drawn out, hazerdous (I mean come on, you've got acid with a pH of 3 or 2 and lye with a pH at the opposite end of the scale) and more effort and energy was required.
Trust me on this one, the base only reaction is so much easier for the homebrewer and a whole lot safer.
Spencnaz is offline
Old 12-14-2005, 11:25 AM   #4 (permalink)
Wow, I appreciate the quick response! I am actually doing the appleseed "standard" biodiesel process so I was interested in this other process just to see if it was better but it appears that it is not. From reading the article it seemed right off that it was more complex than the standard way of making biodiesel.
I have made a couple of test batches using some of the great resources out on the web in this forum and other's like it. I have also purchased and read girl_mark's book and it has helped to answer a lot of my questions. Thanks!
Old 12-15-2005, 02:01 AM   #5 (permalink)
My Photos: (33)
I've been using this formula with good success but the last batch did not go all the way. The coconut oil must have thrown the the ffa off (I have not been titrating). The resultant muc titrated to .7, so I hit it again with 5g/l of KOH and 5% methanol and presto. Lesson learned, TITRATE the oil first. I feel now that there is not enough base added to the Foolproof method. Instead of removing the heat after the first hour, I leave it 50C for the full two hrs while mixing (via pump).
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 340hp Detroit 6V92TA, Eaton 13spd RTO9513, 3.70 ring & pinion and LPG kit. Alcoa 22.5x8.25 with Michelin XVE 255x70x22.5
Huff is offline
