fuel filter problem - Diesel Forum - TheDieselStop.com
Old 02-02-2006, 12:32 AM   #1 (permalink)
fuel filter problem
hi all, first post- on my 1993 f-350 non-turbo idi my fuel filter light keeps comming on, i have changed the thing 2 times in the last month but it keeps comming on at random times, i changed it again tonight, and the light didn't come on for a good half hour then would flicker on for a few seconds and go off again. im stumped. (this truck is converted to run on veggie oil, but this problem only happens when i am running in the stock diesel mode, in the conversion i did switch the fuel route so the diesel goes from the tank to the fuel filter, then to the lift pump, instead of stock which is from the tank to the lift pump then to the filter, could this have anything to do with it? the conversion is a two tank kit from plantdrive.com)
thanks
zack
1993 ford f-350 7.3L IDI non-turbo, burnin clean, free delicous smelling canola oil all the time. veggie or bust.
zackmostov is offline
Old 02-02-2006, 01:11 PM   #2 (permalink)
h2odrx's Avatar
Re: fuel filter problem
welcom to the site? i have seen someone talk about this same problem i just can't seem to remember where? or what they did to fix it? it was something easy tho? help me someone?
Remember, we aren't eating this stuff, we're turning it into diesel fuel. Your truck only cares about viscosity, acidity, and BTUs. Nothing else. -unknown?
NC State law defines biodiesel as ''any fuel or mixture of fuels derived in whole or in part from agricultural products or animal fats or wastes from these products or fats.''
Exemptions from the excise tax
h2odrx is offline
Old 02-02-2006, 02:34 PM   #3 (permalink)
If memory serves right, (this isn't the water in fuel light, correct?) the light comes on when the pressure in the filter drops below a certain level. Since you are 'sucking' through it, instead of pushing through it, the pressure is low and trips the light.
Like I said, if memory serves me right!
1993 Black F-350 Dually Crew Cab
7.3 Factory Turbo upgraded with Banks Sidewinder Turbo
5 speed, 2x4
rollfj is offline
Old 02-02-2006, 11:42 PM   #4 (permalink)
it is the fuel filter light, not water in fuel, and i thought it might me something like that, it only comes on when i give it more throttle, like when i am going up a hill, once in a while the engine surges and gets real noisy for a minute, then pops back to normal and the light comes on. really want to fix it, would adding a second, auxilliary small electric fuel pump fix it possibly, appreciate any advice.
zack
Old 02-03-2006, 01:41 AM   #5 (permalink)
My Photos: (17)
Are you returning veggi to your diesel tank on purge?If so it sounds like you are getting veggi in your filter or you have partial pluged your pick up screen.The surging is from air as is the noise mostlikley the noise is from the timing advancing when the air goes thru the IP it uses fuel presure to retard the timing in the pump.I have the same thing happen because I return to diesl tank on purge it was not a problem when the temps were warmer .I am going to add another valve to purge to veggi tank though.If you still have your old filters cut them open and see what is in them.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline
