fuel hose - Diesel Forum - TheDieselStop.com
Old 03-28-2005, 09:54 PM   #1 (permalink)
fuel hose
Anyone got a good source for flexible 3/8" fuel line [img]/ubbthreads/images/graemlins/shrug.gif[/img]? What are you all using for your installs, and where do you get it?
Brian
__________________________________________________ _________________________________________
2000 F350: Lariat, CC, Black, LB, 4x4, AFE, Magnaflow 4" exhaust, Silverstars, 18K adjustable, TTM, DI 6-pos chip, WW, velvet rides, sonnax/tricum, other cool stuff. Her name: Bertha !
284/599 as of 02-27-05
RazzyB is offline
Old 03-28-2005, 11:43 PM   #2 (permalink)
Banned
Re: fuel hose
Brian, if you are just looking for regular 3/8" fuel line, any auto parts store should have it. Do a search on dexonline for "parker hose" and you should find some stores in our(or closer to your) area.
Scott
sagebel is offline
Old 03-29-2005, 12:07 AM   #3 (permalink)
My Photos: (17)
Re: fuel hose
I am using nylon air brake hose.very tuff stuff and will with stand bio and str veggi.Rated for 200deg I put some in 275 deg oil and it barely made it softer.I got mine at a hose supply house..90cents a foot.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline
Old 03-29-2005, 12:25 AM   #4 (permalink)
Re: fuel hose
brand? cat. #? thx
Brian
RazzyB is offline
Old 04-02-2005, 09:51 PM   #5 (permalink)
CPUNeck's Avatar
My Photos: (13)
Re: fuel hose
Brian,
Not sure if this is late, but I used this from McMaster-Carr
54765K32
(Same as 54765K52)
Nonconductive Buna-N Rubber Multipurpose Hose W/Brass Male X Male Fittings, 25', 3/8" ID, 300 PSI
In stock at $41.35 Each
and have found it really is GOOD hose. Far superior to any fuel hose I've used before. I just got the 25' roll cause it was cheaper than by the foot when I was buying it. Only had like 2' left after the whole conversion [img]/ubbthreads/images/graemlins/grin.gif[/img]
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
SVO Conversion Updated SVO stuff
CPUNeck is offline
Old 04-03-2005, 03:32 PM   #6 (permalink)
Re: fuel hose
Brian,
54765K32
(Same as 54765K52)
Thanks, Clayton, hope you had fun at spring break. Me, I'm dealing with another small issue... [img]/ubbthreads/images/graemlins/bleh.gif[/img] [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Brian
RazzyB is offline
Old 04-03-2005, 07:42 PM   #7 (permalink)
Re: fuel hose
Got 45' of 3/8 PFA teflon tubing for $26 delivered from someone on Ebay. Nice stuff.
1997 GMC Suburban 6.5 Turbo Diesel.
Home made dual tank system.
Burlington,Vermont
asnowsquall is offline
