Re: Fuel Line
You will likely run into issues with the return line from the heads and the hoses from the fuel pump to the fuel canister. I replaced them all and mine is a 97. It will take a while for them to soften up. If you need to replace the fuel bowl or pump in the valley change the hoses.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
