Fuel pump for 7.3 PSD WVO system - Diesel Forum - TheDieselStop.com
Old 06-11-2006, 09:29 PM   #1 (permalink)
I am in the early stages of designing a 2 tank WVO conversion for my 2000 F250 7.3 PSD. I plan to do a second fuel system for the WVO and basically leave the diesel side as stock as possible. I want to do it this way (a)to keep from overworking the factory pump by making it pump WVO and (b)to provide redundancy in case of a failure in one of the systems. I have a couple questions:
(1)What fuel pump/regulator requirements do I have to consider? (eg, flow rate, pressure range, preferred type of impeller or whatever, etc)
(2)What are actual pump/regulator combinations that people have used in converting 7.3 PSD engines that have worked well? I have read that a couple of people have used and recommended the Mallory 110fi pump and corresponding 4305 regulator. Are there any other really good combinations I should look at?
2000 F250 SC 7.3 PSD White w/ 6spd Manual, ISSPRO pyro, boost and FP gauges, Walker BTM muffler on stock exhaust, 6637 air filter, CCV mod, AIH delete, Hutch and Harpoon fuel tank mods
jocko is offline
Old 06-11-2006, 10:54 PM   #2 (permalink)
Re: Fuel pump for 7.3 PSD WVO system
I just got my wvo kit from frybrid. Check out the site. Lots of info.
www.frybrid.com
2000 XLT LARIAT CC SB 4x4, front leveling kit, rear add a leaf, hd overload spring pack, 3.5" down pipe, straight pipe, foil delete, K&N fipk w/dry charger, oil guard by-pass oil filter, coolant filter, ccv mod, 203* T stat & housing, brv+,redhead steering gear box, auto meter boost,EGT, rear diff and trans temp gauges, Frybrid wvo kit, 6.0 trans cooler, BTS trans, 4 position chip stock, hi idle, 60 hp and 100hp, ((XM radio))
MIspecial is offline
