Which Fuel pump? - Diesel Forum - TheDieselStop.com
Old 03-31-2006, 05:54 PM   #1 (permalink)
Which Fuel pump?
I've been reading old posts and there are a few different pumps that people are using, which one(s) is(are) best and why? Lots of different opinions. Any good threads I may have missed?
2000 F-250 Super Cab Longbed
Bright red, they call me "Clifford"
scottefontay is offline
Old 04-01-2006, 12:37 PM   #2 (permalink)
spg
Re: Which Fuel pump?
What are you planning on using the pump for?
2001 International 4700LP T444E 210HP Fuller Six Speed 3.38
spg is offline
Old 04-01-2006, 07:34 PM   #3 (permalink)
I've wondered the same thing, I plan on using it for heated wvo for a 6.9l engine, don't know what the other guy is going for though.
1985 Ford F-250 Lariat extended cab, 4wd auto with Some kind of gears... 3.7whatever I guess, a manual glowplug system, screwed up bed, barely functional wiring, those stupid hubcaps with the seven fake lugs, and lots of rust. Now with an elaborate WVO setup!
Atmus is offline
Old 04-02-2006, 01:39 AM   #4 (permalink)
Have people moved on from the Aeromotive A1000? How about the Mallory? Any tried and true fuel pumps that people are using?
Old 04-02-2006, 11:53 AM   #5 (permalink)
My Photos: (5)
I've been using a SX Performance 18201 fuel pump for awhile now, with no problems. I use a heated in tank fuel pickup with a HIH heater and a temp sender just before the pump, after the engine is up to normal temp oil gets up to 180 degrees and stays there. The pump has no problem pushing hot oil at 80 psi.
2000 F350 SC 4X4 LB XLT 3.73LS DP-Tuner (Stock, 60Tow, 80Econo, 120 Race), ATS turbo housing W/Wicked Wheel, Banks BHA, DIY CCV re-rout, 203* T-stat, Sonnax/Tricum mod, DIY Tymar intake, Frantz Bypass Oil Filter, Autometer 4 Pillar Mount, Jeg's 4" Turbo Back Exhaust, SUVlights harness, Sylvania Silverstar 9007, 45 Gallon Excursion fuel tank, 26 gallon heated WVO tank, Lariat Wheels, BFG A/T 285/75/16's, Snugtop extra vision and Powered by Vegetable Oil!!!
90K miles on WVO and counting
socaps
JoJon is offline
Old 04-02-2006, 06:39 PM   #6 (permalink)
I'm useing the A1000 on my 6.0 PSD. No issues. If I ever do I may try the Mallory since I hear it is easier to rebuild.
B & E
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000, and Vegtherm
Converted at 3900 miles now have 32945
BandE is offline
Old 04-03-2006, 09:54 AM   #7 (permalink)
I just spoke with a Tech at SX performance about the SX Performance 18201 , which has been replaced with by the 18203. He said that as long as the oil is loose there should be no percieved problems using it with vegetable oil. Generally the only problems they see are associated with the use of newer ultra low sulphur fuel blends that wear out the brushes due to reduced lubricity. I think I may give it a try.
JoJon, how long have you been using your 18201?
Old 04-03-2006, 03:42 PM   #8 (permalink)
My Photos: (5)
Going on ten months and 12000 miles, it's a good pump. I got it off ebay (new) for $180.00 about a year ago.
socaps
JoJon is offline
Old 04-05-2006, 03:28 PM   #9 (permalink)
I had used the A1000 pump, it died due to starvation, The 100 micron before pump filter clogged with hose material from a faulty hose. Since then I installed the Mallory 60fi pump running my vegistroke system at 60 psi. with no problems at all.
1996 F350 PSD, CC, DRW, 2WD, Custom conversion, 3" downpipe, BDP stage 1 injectors, BDP 6 pos chip. Autometer gauges. Electric fuel system. CONVERTED to run on Veggie FN74 system modified.
2003 Toyota Matrix
2001 VW NewBeetle GSL TDI
1954 GMC 5 window pickup. in the rebuilding stage, it might even get a DIESEL
KansasDiesel is offline
