Fuel Pump issues - Diesel Forum - TheDieselStop.com
Old 07-28-2005, 12:16 PM   #1 (permalink)
Fuel Pump issues
OK, I had a facet pump on my truck, And it burned up. Literally, where the tire went into the case. So I thought I upgraded and went to a carter 4070 impeller type pump. But after a few hundred miles, it has quit on me a second time. So... I am planning on going back to another facet pump, unless I can get something better/more dependable.
the Carter pump acts like it is at pressure. but nothing is pumping, even after removing the line comming out of it.
thanks
Doug
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 07-28-2005, 01:18 PM   #2 (permalink)
Re: Fuel Pump issues
How much have you spent so far on all of the pumps including time and headache???? You should just cut your losses where you're at and buy an Aeromotive A1000. It may be quite a bit more than you'd like to spend right now but you wont get stuck on the side of the road and you wont have to spend another day driving around town to buy another pump to replace the fourth, fifth or sixth burned up pump. JMO, Steve.
1997 F-350 Crew Cab 4x4 Cali truck - IDM mod (check my webshots), 10k mod, DIY 1C Kit 160cc single shots, fully modified fuel system all electric, seperate pumps with WMO system and tube-in-tube inline heater, typical pillar guages, no cat, no muffler, no ebpv, moded ccv
My Webshots
av8shunmeckaneck is offline
Old 07-28-2005, 01:41 PM   #3 (permalink)
My Photos: (6)
I'm not that familiar with the fuel pump system of your model Ford so educate me a little. I have been using a low pressure Facet rated at 4 to 6 psi as a boost pump to push the veggie toward the stock frame-mounted fuel pump. That works on a PSD.
An Aeromotive would be a much higher pressure pump and is a replacement for the stock pump or used with a dual fuel system like the FN 74.
Just yesterday my Facet boost pump died. I have a feeling it was because I failed to install a screen between the tank and the Facet. My boost pump is plumbed between the veggie tank and the 10 micron Racor filter. I have elected to replace it even though Greasel and others say the stock pump can pull the veggie on through. Somehow it seems like an invitation for a failed factory fuel pump. I'd rather give the thicker veggie a little shove in the right direction.
Todd T
ToddT is offline
Old 07-28-2005, 04:25 PM   #4 (permalink)
So how does the A1000 differ from these other pumps? I will go that way if it is the best, but what makes it better?
The fuel system on this is a lift pump to a mechanical injection pump. Remarkably the injection pump pulls it on through untill it works hard like towing.
thanks
Doug
DSBlack is offline
Old 07-28-2005, 04:42 PM   #5 (permalink)
the local performance shop sells the edelbrock 45 psi 50GPM for 135.00 Is this the same quality?
would it work?
DSBlack is offline
Old 07-28-2005, 10:04 PM   #6 (permalink)
I'd like something that can handle the wide viscosity ranges that our WVO can be when its 40 degrees or 180. I want the pressure and flow to be pretty much constant, and I want the thing to last troublefree for at least 100K. This is why I'm working on build my own. The current pump may or may not be the one. The key is that be playing and experimenting Im learning. It's fun. Check out the post over here.
asnowsquall is offline
Old 07-28-2005, 11:07 PM   #7 (permalink)
thanks
Doug
Since you have an IDI, you don't need the pressure an A1000 gives (to 100psi for fuel injection). Both Aeromotive and Mallory make heavy duty low pressure pumps as well that would last. They cost in the $200-300 range tho. You might be OK with a cheaper electric pump mounted back by the tank.
JOAT is offline
Old 07-31-2005, 09:49 PM   #8 (permalink)
ds--dont run a high pressure pump like that without a regulator on an idi--7 lbs at the most
94_turbo is offline
Old 07-31-2005, 09:50 PM   #9 (permalink)
97 burb--wvo at 40 will be solid--starts at about 48 deg---
94_turbo is offline
Old 08-01-2005, 06:39 AM   #10 (permalink)
Have you looked at Holley ? Summit Racing has the three different models. [img]/ubbthreads/images/graemlins/eek.gif[/img]
http://store.summitracing.com/defaul...=egnsearch.asp
1983 Mercedes 240D 4 speed
Runnin' on B100
My Biodiesel Reactor/Processor
http://www.b100wh.com
biobenz is offline
Old 08-01-2005, 07:27 AM   #11 (permalink)
I think it depends on your oil. I just threw that 40 number out as a ballpark figure. I mean I don't expect the pump will have to deal with 40 degree oil anyways I just want to see what it will do.
Check out my link above for the latest update. Things are coming along great!
