Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > Bio-Diesel and Alternative Fuels
Old 09-28-2009, 08:28 PM   #1 (permalink)
glycerin
can i just pour it in an open container and let the meth evaporate to compost or what??.. i dont need to recapture it as i get mine for free .. ive got to much just sitting around.. thanks
2000 X ,4x4, DIY TYMAR, WALKER BTM, HYPERTECH LEVEL3, AIRDOG 100,
Dirtcheap is offline
Old 09-29-2009, 08:23 AM   #2 (permalink)
That will work, although it is slow. It helps if you can let it set in the sun in a dark (or clear) vessel to warm up and let natural convection turn it over. I have never tried it, as I recover, but I have read it takes up to three weeks to get rid of the methanol. Logically a 55 gallon drum is going to be slower than a pan. The shallower the container the better.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 09-29-2009, 12:02 PM   #3 (permalink)
airfooter's Avatar
Heat expedites the process, but adds significant danger - for obvious reasons.
My bio-d partner has recently mastered soap making! Best soap I've ever used, seriously (from degreaser to shampoo!). We are working on a still to recover the methanol, but he is currently using turkey fryer to heat the glycerin and consequently boil off the methanol.
I've heard the commercial biodiesel folks make as much $$ off their glycerin as they do biodiesel... seems a shame to 'throw it away'. It can also be used by concrete people as form release - most use diesel, so there's a huge savings for them (and $$ for you). Just a couple thoughts!
I'm not cheap - I'm just BROKE!!
2001 F-350, DRW, 4x4, XLT Crew Cab, flat bed, 7.3, 6 spd, LSD, 4.10's NAPA 6637, Dipricol Optix gauges on pillar - EGT, Boost, Fuel Press., HPO Press. - No Muffler, AIH delete, Mobil 1 in trans, t-case & diffs, LUK clutch, Swamps single-shots!!! Vegistroke-inspired WVO system w/95,000 trouble-free miles! DP-Tuner F5 - stock-high idle-40t-60t-80e-100 - Lovin' it!! 203 t-stat w/billet housing, Evans coolant, coolant filter, boost relief valve, Dieselsite IC boots, Hella headlight harness, '07 grill/lites and big, bad front bumper!
2000 Excursion 4x4 Limited - F5, AIS, Frybrid/V3 SVO conversion that does 100mi/day. 30k flawless VO miles so far!
frybrid.com
airfooter is offline
