Have been reading about adding 5% water to the processor before the glycerine settles out, they say this would help preventing emulsion with first wash.....tried it out with 36 liters of new soy oil, seems to have worked well, less than 3 cups of emulsion to clean up aftr the first wash, and overall much easier to wash also.....one thing that i didnt expect was that only the glyerine came out after settling. I had expected a water layer but there was none....anybody doin this routinely that can tell me info?
I do this routinely. Tried it once and never went back. It REALLY makes washing easier. The water and glycerin combine and settle out togther. To my guesstimation, here is what happens. There is still some NaOH or KOH in the freshly brwed bio that would have to be washed out. When you add the water, it latches onto this excess/extra Na/KOH. And because the water really has a tendency to latch onto glycerin also, it all settles out, and... the subsequent washing is easier.
I don't recover excess methanol from the glycerin, but one would have to think that if you did, you probably would want to skip this 5%prewash and deal with more difficult/delicate washing.
2001 XLT 4WD Crew Cab Long Bed. 170k - Mostly stock except: In-tank and pre-pump (and harpoon),AIS (zoodad and fender sleve to come soon). DP tuner.
So you're saying to add 5% by volume of water to the biodiesel/glycerin in the processor prior to draining the tank or just after the 1 to 2 hour agitation?
I'm curious about this as I'm having difficulties with washing biodiesel.
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
yep...really am liking the ease of washing using this technique...strange though if you all are saying the 1.8liters of water come out with the glycerine then i am still puzzled, think i only drained about 1.2 liters total of glycerine...i know there is still some water probably absorbed in the biodiesel though. maybe thats where it is hiding....thanks for the comments..
Uh oh..... I think you said you were doing a 36 liter batch. At 20% methanol, that would be 7.2 liters of methanol going in and I would guestimate you would end up with ~7.2 liters of glycerine byproduct (without the prewash) or ~9 liters byproduct with the 5% prewash.
Seriously incomplete reaction? Tell us what process you use. (You should end up with ~ the same amount of glycerine as the methanol, not considering the prewash water amount.)
I did this on my second batch and it worked great. After your reaction time, add the water and run your pump another 10-15 minutes. There was a noticable difference in the required washing.
<span style="color: blue">2003 SD F250</span>, 7.3 ltr. PSD, Auto, Lariat, White over Gold Crew Cab, FX4 Package, 3.73 Limited Slip, Line-X bed coating, DS External Transmission Filter, AIS Severe Duty, DS 203 degree thermostat, Grill Mod (gutter guard), Ruff Stock Grill Guard, System1 In-line Fuel Filter (pre-pump), Hutch mod, Harpooned, Bridgestone Dueler A/T REVOS, Monroe Reflex shocks, DS Coolant Filter Kit, 119k miles
