A good reason to run B100 over SVO - Diesel Forum - TheDieselStop.com
Old 08-05-2007, 05:17 PM   #1 (permalink)
For those with doubts about the damage SVO systems can cause, see this story,
http://forums.tdiclub.com/showthread.php?t=186108
Murphy2000 is offline
Old 08-05-2007, 06:31 PM   #2 (permalink)
Send a message via AIM to VD350
Re: A good reason to run B100 over SVO
TDIs are known to have issues running SVO and everyone that runs SVO knows what can happen if they dont care about preventative measures. Some have great success other fail, way too many variables with SVO.
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 08-05-2007, 06:39 PM   #3 (permalink)
wow. thats sucks.
2001 black/prairie tan crew cab 4wd lariat
3.5" procomp lift front-factory in the back
35" TOYO open country M/T's on 20" moto metal 951's
PARTS FROM DI 6 posi chip, regulated fuel return, bellowed ceramic coated uppies
Garrett GTP38R
4" turbo back exhaust
Originally Posted by TerminatorEngineering View Post
1/2? That will be an interesting truck to see! :hehe:
dougdoug is offline
Old 08-06-2007, 01:12 AM   #4 (permalink)
CRAP, that's crazy!
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-06-2007, 02:47 AM   #5 (permalink)
I read that story too, but the problem is in his post, he doesn't have any facts about the kit, processing oil, or temp or build of the system. Some people have problems with some cars, and some people don't. I understand that not every car/ truck is a good match for WVO. But still if done right, greasing can work out. You just have to fallow the rules.
2003 F350 w/7.3L, XLT, 2WD, Greasecar kit + 30 fphe
latitude500 is offline
Old 08-06-2007, 10:11 AM   #6 (permalink)
He pretty much admits that he didn't dewater his WVO, too. The valves look like he never waited until his engine warmed up, and didn't really heat his fuel either.
1985 Ford F-250 Lariat extended cab, 4wd auto with Some kind of gears... 3.7whatever I guess, a manual glowplug system, screwed up bed, barely functional wiring, those stupid hubcaps with the seven fake lugs, and lots of rust. Now with an elaborate WVO setup!
Atmus is offline
Old 08-06-2007, 11:27 AM   #7 (permalink)
Spencnaz's Avatar
My Photos: (14)
Even still, no way I"m running WVO heated or otherwise. I had to tear down a friend's 6.2L GM that had seized due to running WVO.
Even heated it scored the cylinder bores and left this peanut butter consistency goo in the bottom of the pan.
While I'm quite sure alot are running WVO successfully in their vehicles, I prefer running a fuel that's thinner by default and has gone through a rigorous chemical and mechanical quality process before running it even in the old Powersmoke.
Spencnaz is offline
Old 08-06-2007, 12:10 PM   #8 (permalink)
I think I would blame the people/kits that claim you can run margerine and hog fat in a diesel on that one. Especially the ones that claim you can dump it straight from the cubes into the tank. I'm not saying that is what your friend was doing, just that he may not have been as careful with the quality of oil/proccessing he was using as he should have.
The stuff I get is pretty good quality as it is, but I boil it and filter it, then remove the stuff that settles and congeals or whatever. The only ill effects I've had so far was a few seals leaking after it loosened all the gunk up, and it doesn't really do that anymore.
I see you have a cowl induction on your truck, do you have any pictures of that? I want to do something like that on mine in the future and want to see how it is done before I go cutting holes in metal.
Atmus is offline
Old 08-06-2007, 01:02 PM   #9 (permalink)
Spencnaz's Avatar
My Photos: (14)
Yeah there are certainly many variables to account for using WVO.
I personally chose to eliminate most of those variables by making biodiesel and only running it in my truck when I had the process down to a high-quality consistency.
As for cowl induction, Hypermax has the cowl induction scoop on their website for the 6.9 diesel.
Spencnaz is offline
Old 08-06-2007, 01:47 PM   #10 (permalink)
What I was thinking about while reading this was:
The TDI's are known for superior fuel mileage. Why worry about getting free waste oil and taking a chance of a major engine repair or replacement.
The pay back in fuel saving by owning a TDI is enough to bring a smile on my face.
I don't own one but have been looking for a deal for some time.
Good luck to all of you who are paving the way with alternative fuels.
2001 Ford Excursion 7.3 New Bilstein shocks, Hellwig rear sway bar, Baldwin Coolant Filter, 81000 miles-1/09/2008, UPDATE 100,200 Miles 7/28/2009, Update 105,000Miles: 12/2009.
1999 Honda Valkyrie Interstate- 14600 miles- , UPDATE 17,700 miles 7/28/2009.
1991 Ford Taurus- 198,000 miles- rebuilt transmission at 105,000 miles-go to work vehicle now.
2002 KIA Sedona- SOLD-
barlowcw is offline
Old 08-06-2007, 06:25 PM   #11 (permalink)
tjbeggs's Avatar
Ok maybe I am missing something here but how does WVO cause turbo damage, cylinder scruffing, and intake valve build up on a direct injection system. I am new to BD and don't want to run WVO but I don't think the damage to that engine is due to WVO. I think he had poor air filtration that took out his turbo and damaged the piston and cylinder and as for the build up on the intake valve a poorly operating CCV system. I don't really know but that damage doesn't seem to jive with a WVO issue.
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
Originally Posted by action4478
Most people come here for the facts ...not a hug ...
tjbeggs is offline
Old 08-06-2007, 06:47 PM   #12 (permalink)
I had a long conversation with a guy from British Columbia who has nearly 200,000 mile on his 6.9 IDI run WVO, was he lying to me? I doubt it!
Stefan, 2000 F 250 CC 4x4 PSD SB, Weld Wheels, 35" BFG AT's, Line-X'd, Ride Rites, Auto Meter Guages, Leer Shell, Rancho Lift & Chipped,
1993 F 350 SC 4x4, Banks Sidewinder, Eagle Wheels, 35" BFG AT's
Truck, Hunting and Fishing Pics
Stefan is offline
Old 08-06-2007, 06:53 PM   #13 (permalink)
Spencnaz's Avatar
My Photos: (14)
The IDI 6.9 is very tolerant of fuel quality. I joke with people saying that my truck could run on boiled horse pee and not know the difference.
The kicker with WVO is dewatering, near fanatical filtration and lots of heat before it even enters the fuel injection system.
WVO doesn't address the free fatty acids issue that is eliminated by turning WVO into biodiesel. Washed biodiesel not only removes all these free fatty acids, but also water, alcohol and any other particulates and is much less viscous than WVO further removing undue stress on the injection pump.
WVO can kill the IP on the 6.9 IDI engine if it's run too cold, I have heard of instances of poorly warmed WVO causing the input shaft on the IP to snap due to excessive shaft stress.
Spencnaz is offline
Old 08-06-2007, 07:05 PM   #14 (permalink)
something else was happening with that guys car. it seems he was getting incomplete combustion for some time. What did his intake look like? how clean was his air filter? Clogged snow screen? OIl changes? Did he mention any of these factors?
1993 Ford IDI 7.3L
F-250
ZF-5 speed 4 wheel drive
Class 5 hitch
D load tires <img src="/ubbthreads/images/graemlins/frown.gif" alt="" />
super cab
18x,xxx miles.
Purchased 9-22-06
luckys420 is offline
Old 08-06-2007, 07:09 PM   #15 (permalink)
Spencnaz's Avatar
My Photos: (14)
What I found the most alarming was the accumulation on the valve stems, I mean how would those valves be able to close with that much crap on the stems.
Spencnaz is offline
