Greasecar Excursion? - Diesel Forum - TheDieselStop.com
Old 03-14-2006, 07:08 PM   #1 (permalink)
I was pointed in the direction of Greasecar.com for their vegetable oil conversion kit for the Powerstroke (where you can run your Ex off of McDonalds old fry oil). Two questions:
1. Has anyone had any real world experience with this? I can see the grin on the F*rd warranty accountants face already...
2. Does anyone know of an aftermarket fuel tank that will bolt underneath the Ex in place of the bed mounted tank greasecar offers?
Am I asking for it by even investigating this?
Thanks,
Scott
'02 PSD Excursion 4x4 - Mag-Hytec rear differential cover, Racor CCV Filter, Banks Transcommand, V-codes, Hellwig rear helper springs, 9000X's + steering stabilizer, 30mm rear sway bar, aFe, Magnaflow SS exhaust, X monitor, H/X & pre-pump/tank mods, Oilguard bypass filter, coolant filter, SCMT, Prodigy braking, BFG AT's.
seseattle is offline
Old 03-14-2006, 08:01 PM   #2 (permalink)
Re: Greasecar Excursion?
there is a forum here dedicated to Bio and alternative fuels
you might check there.
Bruce
Bruce1954 is offline
Old 03-15-2006, 02:11 AM   #3 (permalink)
Let me do you a solid. You are right there in Seattle. Head over to Frybrid and have them do it right. If you have any questions visit http://www.frybrid.com They've got some growing pains they are going through right now, but since you are local you can work through them. Bar none best WVO products out there. The tank is an issue on the Excursions. It would probably have to be fabricated. Frybrid can fabricate one...and if you'd be so kind as to take your truck over there so they can measure I won't have to leave mine in Seattle as long.
I'd advise against Greasecar, Greasel, Vegpoweredsystems, and a host of others. You aren't talking about a disposable $2500 old beater Mercedes here. You'll want to do it right, especially when winter time comes. The only company I'd consider besides Frybrid is Plantdrive, and then only after they've made the product changes they've promised me.
To their credit Greasel has a tank and system for the Excursion. Problem is their system is full of Greasel components.
FWIW, being able to operate an Excursion on WVO is the only reason I can legitimize the purchase. I drive about 3K miles per month on company business. I'm wholly in favor of getting 45.5 cents per mile with essentially no fuel cost.
rexleone is offline
Old 03-16-2006, 07:40 PM   #4 (permalink)
You might want to check into Vegistroke.com as well. He is in the Seattle area. He specializes in the 7.3L Powerstrokes. I have one of his systems and I am pleased with it.
2001 F-250 Lariet Crew Cab 4x4
190,000 plus miles
Vegistroke kit at 95,000 miles
BTS Transmission at 120,000 miles
Superchips 1705 Programmer
Quadzilla Commander Monitor (EGT, Boost, Tranny temp, Fuel Pressure, EOT)
powerg is offline
Old 03-17-2006, 05:42 AM   #5 (permalink)
I have well over 12,000 miles on my truck since I converted. The Plant Drive Kit I have is working perfectly.
B & E
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000, and Vegtherm
Converted at 3900 miles now have 32945
BandE is offline
Old 03-17-2006, 12:05 PM   #6 (permalink)
My Photos: (5)
vegistroke.com All the way, he's done a Ex before. All the other kits are way over priced!
2000 F350 SC 4X4 LB XLT 3.73LS DP-Tuner (Stock, 60Tow, 80Econo, 120 Race), ATS turbo housing W/Wicked Wheel, Banks BHA, DIY CCV re-rout, 203* T-stat, Sonnax/Tricum mod, DIY Tymar intake, Frantz Bypass Oil Filter, Autometer 4 Pillar Mount, Jeg's 4" Turbo Back Exhaust, SUVlights harness, Sylvania Silverstar 9007, 45 Gallon Excursion fuel tank, 26 gallon heated WVO tank, Lariat Wheels, BFG A/T 285/75/16's, Snugtop extra vision and Powered by Vegetable Oil!!!
90K miles on WVO and counting
socaps
JoJon is offline
Old 03-23-2006, 12:54 PM   #7 (permalink)
My Photos: (11)
Didn't his engine blow up while running his own kit?
isakmpd is offline
Old 03-23-2006, 11:03 PM   #9 (permalink)
My Photos: (5)
Rodneys right, he was running on #2 fuel at the time.
socaps
JoJon is offline
Old 03-24-2006, 10:27 AM   #10 (permalink)
My Photos: (11)
Thanks for the clarification as I am seriously looking at that very kit.
[img]/ubbthreads/images/graemlins/phoney.gif[/img]
-matt
isakmpd is offline
Old 03-24-2006, 10:43 PM   #11 (permalink)
My Photos: (13)
FWIW, Greasel's Nomad system has been great for me...
The Excursion is nothing more than an SUV version of an F250/350. Charlie over at Greasel did his own excursion with a very interesting system.
I'm not sure why the previous poster doesn't like Greasel, but they did a good job for me.
Good luck.
Y2k PSD; 60k miles SVO; Dieselsite 203 thermostat Greasel Nomad 140; Line-X; Frantz bypass oil filter; AFE intake; $10 AIC; Cup holder upgrade.
blitzlaw is offline
Old 03-25-2006, 01:39 AM   #12 (permalink)
Spencnaz's Avatar
My Photos: (14)
Tell you what, since you are in Seattle, why dont you send me a private message, and I'll show you how to make biodiesel for much cheaper than spending all that cash for a conversion.
Spencnaz is offline
Old 03-25-2006, 04:10 AM   #13 (permalink)
Isakmp- Yep, sure did blow the motor while running my own kit. [img]/ubbthreads/images/graemlins/frown.gif[/img], no doubt that was a costly endeaver. However, as a few have mentioned, it can not be directly connected to my vegoil kit. There are those who have blown their motor while running on # 2 as well, having never used WVO. I was just a not so lucky recipient of a defective part, and power mods. As I mentioned, I do not baby my truck, I am brass juevos to the wall all the time. However, I do the reuqisite maintainance as well. I have done blackstone oil samples since I first started, and even my last one they could not see this coming. And Swamp even noted that my engine was in very good health. The excessive carbon buildup on the injectors was no doubt from my earlier attempts at running 100% WVO. If you want I would be happy to give you the phone numbers of any of the whopping 10 customers I have had so far. Everyone seems happy to spend 2500 to do it themselves then spend 2,000 from me. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Oh well, no biggie. I am happy that I had a chnace to look inside my motor anyway. Now I can rebuild it for some serious power!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
fordnut74 is offline
