Heated Fuel Filter Bowl on 7.3L? - Diesel Forum - TheDieselStop.com
Old 11-14-2005, 04:46 PM   #1 (permalink)
I have a 2001 Ford F-350 PSD and I have just started to make big batches of biodiesel and I was wondering if the fuel filter bowl is heated. Would the heated fuel filter help out on not letting biodiesel not cloud up in the cold? I do not plan to run B100 in the winter as I do not want any gelling to occur.
2001 F-350 Lariat, 7.3L PSD, Auto, CC, SRW, SWB, 4X4 ESOF, True Blue/Harvest Gold, Heated Seats, Reverse Sensors, DP Tuner 4 Position Chip, WD Turbo Gauges, WD Turbo Brake III, AFE Stage II Proguard 7 Intake, Magnaflow 4" SS Turbo-Back Exhaust System, ATS Compressor Housing, Turbomaster Wastegate Controller, Goodyear Wrangler SilentArmor LT265/75R16/E, Rancho 5406 Steering Stabilzer, Bilstein Shocks, AIC with ITP bracket, APC Euro Front & Rear Lenses/Projector Headlamps with Sylvania Silverstar Bulbs and wiring harness, Stull Billet Grill, Rhino Liner, Using Schaeffer's Supreme 9000 5W-40 oil with Puralator Oil Filter, Magnefine Tranny Filter with Specialty Formulations ATF, 203* Thermostat, Dieselsite Coolant Filter using Fleetrite ELC, Running Homebrewed Biodiesel B100.
Truck Pictures
ford_diesel_man is offline
Old 11-14-2005, 09:00 PM   #2 (permalink)
Re: Heated Fuel Filter Bowl on 7.3L?
I don't know about the 2001's but my 2003 7.3 does have a heated bowl. Tell you how to find out. The next time you change the fuel filter, look down in the bottom of the bowl. If you see a little circular heating element runing around the perimeter of the bowl bottom, you have one! Seriously, it looks a little like the burner on an electric stove only there is a single loop, not multiple loops. You can even see where the wire connects to it.
I'm sure that it would have to help gelling at the fuel filter, which is the most likely place to gel. Between the heater and the friction generated by pumping the fuel, it would probably add a little heat to the tank too. I'm in Central NC, not too far from you climate-wise. Experienced folks here tell me not to go below about 25-30% petro diesel in the cold months. Remember, depending on your feed stock for biodiesel, it can gel even at relatively high temperatures (50 degrees F. plus). Cutting it with petro diesel will keep that from happening.
2003 F-250 4X4 Lariat Crew Cab 156" WB, Arizona Beige over Black, 7.3 PSD,Superchips 1705 "tow safe", auto, 3.73 limited slip, X-Monitor, ARE hard tonneau cover, Line-X bed liner, Ford splash guards, vent visors, hood wind deflector, 50 gal Transfer Flow in-bed tank, Powerslot cryo rotors (front) with Hawk LTS pads, Ford AIS with fender sleeve, V3 Back-up Camera, Marinco mod.
kc_maverick is offline
