Has anyone tried to warm the fuel in the stock tank? If so what did you do. I run B-100 until it gets too cold and then I blend with diesel. Temp. here was 9 degrees yesterday morning and fuel started to cause some problems. I will install the heated Dahl but would like to be able to warm the fuel in the tank if possible. I was thinking about something like this: http://www.campingworld.com/browse/s...6&src=SRQB
'06 (built 1/06) F-350, CC, DRW, Lariat, stock for now, running on B-100 most of the time.
Looks like a workable idea but...
How long are your batteries gonna last keeping this thing at 60+ degrees?
Also not sure of the legal issues concerning a setup like this. I understand the flash point of diesel...however I'm not sure anybody's insurance company would cover a vehicle (or the other guy)if they found out this was attached.
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
Actually, with regards to insurance, this is probably less intrusive than most systems. We mess up any tank safety certifications when we cut a hole to insert a coolant heat exchanger.
The idea is to get your temperature high enough to flow. If you start with this external 'warming' pad, add the Dahl, plus a plate exchanger, some more hose/in/hose or hose/on/hose.... you may be able to get enough heat. It is experimental from what most are doing now but who knows?
I'd suggest getting the heat up quite a bit before trying to run it through the Dahl. Thick grease would likely mess up the design of the fuel flow through this type filter, even more than others. Also, consider adding a low pressure boost pump of some sort. The stock pump won't last long trying to draw such a thick oil. However, I think the Dahl must be on the suction side.
What if you go to a heated filter that can handle a low pressure feed? There may also be other external heaters though this is the first time I've seen this Camperworld unit mentioned. Creative.
Todd
My thought is to wire it in with the block heater. Heat with 12 volt after startup at the tank. Install the heated Dahl before the pump.
I only need to get it warm, not hot, because of the blend of BioD with kero. It was 4 degrees the other morning and the truck complained but did get me to work. Just looking to take the edge off the cold fuel without any major tank mods.
Has anyone figured a way to heat our tanks with coolant from the engine? I thought that would get too hot for a plastic tank.
I believe Greasel's excursion kit involves heating the stock tank and adding their custom aluminum tank midship. I'm not 100% sure but I think they essentially drop a coolant based heat exchanger into the tank. They seem to consider their excursion conversion to really be the cat's nuts... and AFAIK it probably is a good conversion. Only thing is that last I checked they insist on doing the install. You might give them a call though and see if they'll give you something custom to suit your needs (i.e., just a tank heater, either they install or you install). Really though, the solution you found there looks to me like it'll cover your needs. Just tossing out another possible option in case you want to check it out.
Good Luck!
Charlie
2000 Ex Limited running wvo on two tank/checkvalve system (modeled after fordnut but not as fancy); Bilstiens; Coolant filter.
I used a couple aircraft bulkhead type fittings, flared some 5/8 flexible aluminum tubing and routed coolant through it. My tank is steel though. For your plastic tank I’d heat a spot with a heat gun, check temp with a point and shoot temp gauge, and see how flexible the tank is at 190deg before doing it with coolant.
96 E350 Running SVO. 110 gal grease tanks, 13 gal dino fuel tank. All under van. [img]/ubbthreads/images/graemlins/smile.gif[/img]
I have looked at Greasel and some others.. I think I will make my own from stainless tubing ordered from here http://www.mcmaster.com/.
I don't want fittings inside my tank to leak or copper for noncompatibility. I have to make the coil, have both ends stick out the top through a plate than can be screwed and sealed on the tank.
I will probably put and inline coolant heater in the connecting hose.
All I have to do now is find the time.
heres a premade one that are not too bad of a price.You could also put a control valve on the feed line to stop water flow when not needing heat to tank.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
