Re: HELP ! I'm looken 4 Viton Gaskets 2002 7.3 fuel filter cap & drain
I wish I could give you some ideas on that triangle shaped O-ring on the fuel filter housing.
I finally just did away with that expensive factory filter after I had problems with junk screwing up the fuel pressure regulator.
With probably 10,0000 miles or more running B-100 I never had the drain valve leak but I knew it was only a matter of time with those Buna-N O-rings. For the drain, you can buy a rebuild kit and take them down to an industrial supply house to have them measured for replacements. Check on the 7.3 forum as I recall somebody listed what O-rings are included in that rebuild kit. It was years ago though.
