Homemade 55 gallon steel cone bottom tank - Diesel Forum - TheDieselStop.com
Old 12-31-2005, 05:10 PM   #1 (permalink)
Some time ago I ran across a post that had a design/plans for building a cone bottom to a 55gal drum. Is there someone out there that has the plans? If no luck I will try some cardboard cutouts and see if that idea would work what do you think?
02 Ford Excursion 7.3 powerstroke 2wd. Rancho RS9000, B100 summer, B50 winter
94 F350 Crew Cab 7.3 idi turbo, no muffler, B100 summer, B50 winter
rodman68 is offline
Old 12-31-2005, 05:14 PM   #2 (permalink)
Re: Homemade 55 gallon steel cone bottom tank
If you are good at math, here you go.
Now understand, I dno not agree with most of the info on this site, but these plans seem worth looking at.
Rick H...
Cone Bottom Steel Tank
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
Old 12-31-2005, 05:44 PM   #3 (permalink)
Thats the one thank you very much!!
rodman68 is offline
Old 12-31-2005, 09:16 PM   #4 (permalink)
Saw this on another post the other day. It might save some work.
Scroll down untill you see the "Heavy Duty Funnel"
http://www.gamefeeder.com/accessor.htm
'06 (built 1/06) F-350, CC, DRW, Lariat, stock for now, running on B-100 most of the time.
jdr01 is offline
Old 01-03-2006, 01:24 AM   #5 (permalink)
DIESELMIESTER's Avatar
Checked out that pre made 55-gal funnel/cone at that feeder site its galvinized which is not a good idea to use if you ask me. Would be perfect if not. [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]
96 F-350 SRW LB STRETCHED 6-DOOR, PSD 5SPD,DETROIT LOC REAR, 4X4, 6 POS CHIP, 5'' STRAIGHT EXHAUST
DIESELMIESTER is offline
Old 01-03-2006, 01:29 AM   #6 (permalink)
You can strip off galvanizing by soaking the metal object in muriatic acid (hydrochloric acid) which is cheap at the hardware store paint section. For a funnel/cone I imagine you'd just brush the acid on and later wash it off into a tub (don't hose it off onto your lawn or anything). I remove galvanizing from items I"m going to weld by soaking them in a bucket of the stuff- if you keep the bucket sealed the acid stays 'good' and usable for a long time.
Mark
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
girlmark is offline
Old 01-03-2006, 02:07 PM   #7 (permalink)
I guess its not so bad to get the galvanization off, will keep your plans in mind for removing. Its probably worth the time savings to just buy the galv funnel and acid wash rather than to make a funnel. By the way I just ordered your book. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Old 03-28-2006, 10:51 AM   #8 (permalink)
Hey rodman68 or anyone else, I have a pattern for the cone that goes on a standard 55 gallon drum. Its easy to make and easy to roll.
We made 2 cones with this pattern for our stainless steel reactors. The tanks are tall and skinny and are the same diameter as a drum.
Just lay the pattern down on the steel, chalk it out, and cut.
If the metal is thin...you likely could roll it by hand OR if its kinda thick...then have someone with a set of metal rolls roll it for you.
Overall its a pretty easy project. On a scale of 1-10 with 10 being the hardest, I'd place it at a -2-.
If you need the pattern...just let me know and I can duplicate my pattern and drop it in the mail for you.
- Chad
PS: If anyone knows anyone who might be interested in a 400 gallon cone bottom HDPE tank...let me know. I have a few of them I need to get rid of. (The manufacturer had a minimum order.) Would be great as a large wash tank for biodiesel, a storage tank, settling tank or if you do it right a reactor. 814-450-5771
chaddadams is offline
Old 03-28-2006, 02:55 PM   #9 (permalink)
PM sent, I'm interested in your cone bottom design.
Sounds easy,
Hugh
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 03-28-2006, 08:32 PM   #10 (permalink)
chadadams-be interested in your cone bottom also-thanks
94_turbo is offline
