Old 10-12-2004, 07:01 PM   #1 (permalink)
Hose material
What are you using for hose for this set up. I am thinking of making my own, I have the tank and will go with a trans cooler to heat the oil but will regular fuel line work in this?
Doug
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 10-12-2004, 08:34 PM   #2 (permalink)
fordlover's Avatar
Re: Hose material
Doug,
I am going to use fuel line and heater hose and make my own also i think i will heat shrink it together.
Tony
96 F250 PSD 4X4 Crew Cab, Automatic,355 gears, Diablo 3 stage Flip Chip, no kitty,Ranch Hand rear bumper,Icom 706 HF radio,Icom 208H dual band,home made intake,Hella 450 fog lights Hella 4000 driving lights Hella FF200 fog lights,Autometer Boost & pyro gauges (((XM))) Satellite Radio
fordlover is offline
Old 10-13-2004, 12:31 AM   #3 (permalink)
Re: Hose material
I also can get some plastic tubing that we use to run acid through at work (it would be new) we run it at 130C would this handle the temp?
Where are you going to find heat shrink that big?
Doug
DSBlack is offline
Old 10-13-2004, 10:21 AM   #4 (permalink)
fordlover's Avatar
Re: Hose material
They have it at McMaster Carr supply it costs about 1.00 a foot but I may use poly tubing for the heater hose instead that would be 1/2" and 1/4" for the fuel line
Tony
Old 10-13-2004, 11:31 AM   #5 (permalink)
My Photos: (6)
Re: Hose material
Be careful about the poly hoses. I have yet to find any 'see through' hose that can handle above 130 degrees.
Todd T
ToddT is offline
Old 10-13-2004, 08:27 PM   #6 (permalink)
fordlover's Avatar
Re: Hose material
I had a concern about that I was going to check the specs on it i thought I saw some that was good to 225 but i am not sure if it is poly or pex I will go and do some research on hose before I do it.I may just have to use regular heater hose.
Tony
Old 10-13-2004, 09:13 PM   #7 (permalink)
Re: Hose material
The plastic stuff we have runs at 130C constant. So that converts to 266F. Should be ok? It is not completely clear and has some teflon in it. I guess I will have to watch it close?
DSBlack is offline
Old 10-14-2004, 08:57 AM   #8 (permalink)
My Photos: (6)
Re: Hose material
I'm interested in that for my company use in industrial cleaning. My local suppliers can't get me over 130 degrees F. Could you send me by PM the name of your distributor so I can find out more? Interesting.
Thanks...
Todd T
ToddT is offline
Old 10-14-2004, 09:24 AM   #9 (permalink)
Re: Hose material
I will do some checking. What we have is left over from tool install. But I can find out something. Give me a few days.
DSBlack is offline
Old 10-21-2004, 01:09 AM   #10 (permalink)
My Photos: (17)
Re: Hose material
My brother inlaw has been running his Jetta on WVO for 10,000 miles now.He used one inch hose with the opac white poly type tubing inside to run the oil thru.On each end He has a tee the poly runs straight out thru a compression fitting to seal it Out of the branch the water is routed to the engine and to the tank .The tank has a oil cooler for a heat exchanger.He used the style with inverted flare fittings and used steel tubbing to connect to the exchanger and out of the tank to the coolant lines.I am leary of using rubber hose on my truck due to the length.I was thiking to use the poly tubbing and run it inside of some sealtite flexable conduit.It would protect it and hold all the tubes together.I was thinking of using 1/2 inch lines but not sure if that would be enough for the water.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline
Old 10-21-2004, 01:23 AM   #11 (permalink)
My Photos: (17)
Re: Hose material
Hey DS we should get together if you are going to convert to you can email me at yacoltman69removefirst@yahoo.com.
350 Long Rod
Old 10-21-2004, 05:49 AM   #12 (permalink)
CPUNeck's Avatar
My Photos: (13)
Re: Hose material
Hey 350 Long, can you get some picks of the hose-in-hose fittings? Or perhaps a link? I'm going to augment the kit I have on the way and HIH is what I want to do. Thanks [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Early 99' Upgraded to 99.5' F250 XLT SWB PSD, 4x4, GPT38, EBPV Delete, Perf Friction 2-pcs rotors, 4" turbo back exh, Ford AIS, 6leaker OEM cooler, Htr Core by pass valve, Synthetic every fluid (Mobil), Detroit LOCKER, BTS, Lunar Autometer gauges, DP-F6C, 235k mi
SVO Conversion Updated SVO stuff
CPUNeck is offline
Old 10-22-2004, 01:27 AM   #13 (permalink)
My Photos: (17)
Re: Hose material
you just use standard mptxcompression fittings you my have to drill out a little bit thru the mpt side.So the poly comes out of the rubber hose thru the tee and thru the compression fitting and on to tank or filter or what ever is next in your setup.
350 Long Rod
Old 10-24-2004, 11:40 AM   #14 (permalink)
My Photos: (17)
Re: Hose material
UPDATE I was wrong on the type of tubbing it is not poly it is teflon
350 Long Rod
