How long does Veggie oil Keep? - Diesel Forum - TheDieselStop.com
Old 07-30-2008, 12:58 PM   #1 (permalink)
I've had about 50 gallons of 50:50 WVO and diesel sitting around in my tank for a year now and was wondering if it is still good or does it spoil/grow algae in it?
1996 PSD, XL, 2wd, SRW
331,000 miles. Amsoil Synthetic, and Cat extended life coolant. Diesel Site 203* T-stat. 4 inch straight piped exhaust. Tymar intake. Leather Captains Seats. 120 gal. Heated Veggie tank in rear. Shimmed FPR. TS 6 Pos. Chip (stock, hi-idle, 50,75,100,140). DIY Stage 1 160cc injectors. Valaire Con O Clutch. Stainless 10" drop 15K hercules rear bumper. 3 gauge pillar pod: autometer digital boost, pyro, voltmeter. BFG AT's 285/75/16
Pulling a 31' 1985 Airstream Excella
1986 Hunter 23
huberjoshua is offline
Old 07-30-2008, 01:26 PM   #2 (permalink)
Depends on alot of things. If it could get light, if it had water in it, how hot it was while it was sitting... etc. Only way to know is pull some out and look at it.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 07-30-2008, 04:59 PM   #3 (permalink)
I would be more afraid that the two would separate and have a layer of WVO, and a layer of diesel.
The additives in the dinodiesel should add some protection to the WVO while they are mixed. If they separate.....
'99.5 F250 crew cab, stock
'02 Excursion stock
Check out my blog: The Fixit Shop
scbaguy is offline
Old 07-30-2008, 05:24 PM   #4 (permalink)
hheynow's Avatar
I'd siphon the tank and see what it looks like. You may want to reheat, de-water, re-filter then add a biocide. Vegoil once de-watered can last a year or more if stored in an air tight container and out of sunlight.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 08-02-2008, 11:19 AM   #5 (permalink)
How long does strait WVO keep? I have a line on some, but havent done the conversion yet. I figure I may as well get ahead on my supply. So, I plan to get the WVO in 55 gal drums, and store it behind my shop. If it cant get air, will it keep OK? Should I wash / filter it before I store it? Any good links on filtering and washing etc? I am just getting my feet wet on the whole WVO thing
Y2K PSD CC 4x4 Shorty.
81 Toyota Rockcrawler LT1 Dana60 /14 bolt, dual T-cases. 44"TSLs
roktoy is offline
Old 08-02-2008, 04:01 PM   #6 (permalink)
hheynow's Avatar
Dry oil (fully de-watered) will last up to a year if stored in an air tight container in a cool dark place. Bacteria in the water portion of the oil with heat makes WVO rancid so yes filter, de-water and store the sealed container inside. Adding a biocide is always a good idea for long term storage. Direct sun =
hheynow is offline
