How many miles on WMO? - Diesel Forum - TheDieselStop.com
Old 08-07-2008, 10:36 AM   #1 (permalink)
ReefBlue's Avatar
Who's been running for a while on this stuff?
I'm somewhere around the 1500-1800 mark. I'm running 80/20 or even higher.
Does anyone have something like 25k or even into the 6 figures?
Also, I don't mean adding 2 gallons every 3 tanks. I'm talking about basically substituting WMO for diesel.
ReefBlue is offline
Old 08-07-2008, 11:38 AM   #2 (permalink)
Im over 1200 GALLONS burned. that almost qualifies for what you are asking.
I have experimented with a lot and normally run a 90/10 mix. I may move that down a bit but have had no problems to date.
1993 Crewcab 4x4 coverted extendcab,7ft bed , upgraded rebuilt E4OD w/ shift, new shocks, 3.55, Eagle aluminum wheels,1996 bumper, front buckets, ATS turbo w/ 4inch custom exhaust in process,60 gal aux tank for alt-- err extra fuel
1984 300SD single tank mix doing great
1998 Mountaineer FOR SALE
1994 Bronco w/ 1995 Lightning motor..wa hooo
jski55 is offline
Old 08-07-2008, 03:42 PM   #3 (permalink)
LunaTech's Avatar
I've got about 6000 miles running a 75%wmo 25% diesel. Like jski said, not problems to date.
1994 F350 IDI with factory Turbo, crew cab long bed with dual tanks
LunaTech is offline
Old 08-07-2008, 07:06 PM   #4 (permalink)
44swamper's Avatar
very nice, I'm on 50/50 now and have ran as much as 70/30 with no problems. Done 70/30 on WATF as well. Only been doin this for a month now.
2000 PSD XLT CC, AT, 4x4, DP-Tuner, straight exhaust. Sonnax/Tricumulator, 6.0 tranny cooler. Cyberdyne tranny guage. Straight #2 and every now and then a bit of tranny fluid.
44swamper is offline
Old 08-11-2008, 07:09 AM   #5 (permalink)
gamudslinger88's Avatar
I have around 5k miles on mainly 50/50 and sometimes up to 70/30. anything more than that my truck doesnt run as good and smokes at idle. I have pulled around 11k and with no problems for around 1000 miles. Runs great on wmo and zero problems to date. My dad started running it in his 12v dodge and gets around 100 more miles per tank. Great stuff.
2001 F250 4x4 long bed extra cab 6 speed hand shaker . DIY Tymar, 4" turbo back straight pipe w/ 5" stainless tip, DP tuner F5 w/ stock, high idle 1200 rpms, 60hp tow, 80hp econo and 120hp performance. Auto meter Boost and EGT gauges on an A pillar pod. 203* thermostate. BRV+, CCV mod run to the back between fuel tank and skid plate. 2.5" leveling kit and running 315/75/16 Hankook MT. Cobra CB with dual 3' whips. 12000 miles + on WMO and ZERO problems.
Huge make over on the way.
6.5 Procomp lift, 20" Motos wraped with 37x12.5 Procomp Rubber.
Soon to follow. Ranch hand bumpers, GT38R turbo, High performance HPOP, Head studs, 6" miter cut stacks.
gamudslinger88 is offline
Old 08-11-2008, 02:42 PM   #6 (permalink)
I should say that I have a heat exchanger hooked up before the fuel filter. And that I normally run on straight #2 before switching to my mix AFTER Im at operating temperature. Just to set the record straight and not confuse anyone.
jski55 is offline
Old 08-11-2008, 05:05 PM   #7 (permalink)
how many miles
just started last month running about 60/40 no problems so far . does seem to run quieter and pulls a steep locale hill all the way in o/d now ????
scottp. is offline
Old 08-11-2008, 09:16 PM   #8 (permalink)
bucke96's Avatar
I have about 30,000 on mine now with WMO. I've been running ATF only. I started out for a few months at 25% ATF - 75% #2 and it ran good so i just jumped to 100%. I just depends on how much i can get, but i run just a couple gallons here and 100% there. Most of the time im around 75% to 100%. I would recomend that if you tow keep the ratio of WMO down. My truck does seem to do better on #2 while towing. No problems yet and its free.
My buddy that turned me on to this has about 50,000 on his truck running 75%-100%. No probs.
02 F-250 4X4
96 F-250 4X4
bucke96 is offline
Old 08-11-2008, 11:40 PM   #9 (permalink)
where do you guys get all your WMO?
2000 F-250 SC Lariat 4x4, 7.3L PSD, Sport Comp Gauges (trans/boost/pyro), Ranch Hand Front, AFE Stage II w/Proguard 7, MBRP 4" Exhaust, DP-Tuner w/F5 (80 econo/100 perf/60 tow/80 tow/high-idle), Tru-Cool Tranny Cooler, DieselSite External Tranny and Coolant Filter Systems, 203* Thermo, Bilstein HD Shocks, Putnam Class V 16K.
xnoto is offline
Old 08-12-2008, 12:16 AM   #10 (permalink)
DHTD's Avatar
Im starting to get really bummed on the biodiesel thing. I build a processor. I finally score what I think is a great oil source only to bring 25 gallons of it home and have it titrate at around 30, and it looks like good oil. Cannot even make a 1 liter batch successfully. Not to mention I just set them up with a lockable drum that didnt cost me much but I had to spend a few hours grinding, welding, and cutting to make it fit.
The good news is wmo is abundant and it seems everybody wants you to take it away.
Thanks for those posts guys, you really made me feel at ease, Ive been slightly worried with running this stuff, even though I have around 300 miles and running great. It was just nice to hear, 50,000 miles and no problems!!!
01' 7.3 4X4 DRK MTLC BLU, DP Tuner F5, AEM Intake, 4" Turboback Silverline Exhaust, BTS VB, AEM digital gauges(pyro, boost controller, trans temp), CCV mod, Rebuilt Injectors, Fuel tank Mods, 203T, 6.0 Trans Cooler, 185,000K and original tranny, so far so good.
DHTD is offline
Old 08-12-2008, 12:19 AM   #11 (permalink)
bucke96's Avatar
My buddy is a diesel tech at a local dealership and he talked them into letting him take all of thier flushed trany fluid. When they flush a trany the ATF goes into a couple jugs he has there, then straight to my house and into my holding tanks. The dealership doesn't have to pay to have the ATF taken away and we get free fuel. Not a bad set up.
02 F-250 4X4
96 F-250 4X4
bucke96 is offline
Old 08-12-2008, 12:23 AM   #12 (permalink)
bucke96's Avatar
One more thing to remember, filter-filter-filter and oh ya filter good.
02 F-250 4X4
96 F-250 4X4
bucke96 is offline
Old 08-12-2008, 01:06 AM   #13 (permalink)
Shhhh! Don't let this get out!
tweener is offline
Old 08-12-2008, 07:41 AM   #14 (permalink)
ReefBlue's Avatar
So ATF works well also? I just did a fluid change, so I've got 3.5 +/- gallons in milk jugs.
Is it just like WMO? Good filter and then pour it in?
ReefBlue is offline
Old 08-12-2008, 08:29 AM   #15 (permalink)
yes and it usually is much thinner...
jski55 is offline
